Spark Plug Question
Old Apr 14, 2005 | 05:53 PM
1BADFNZ's Avatar
Default Spark Plug Question
ok out of the 6 plugs I got today #'s 2 & 7 had some oil at the top of the threads (top being part furthest away from electrode) They were all kinda reddish in color... is this good or bad.
Attached Thumbnails Spark Plug Question-new-camaro-223.jpg   Spark Plug Question-new-camaro-224.jpg
Old Apr 14, 2005 | 07:04 PM
HavATampa's Avatar
Does the car puff blue smoke? I'm betting a valve cover leak. With that much oil you would look like a mosquito fogger going down the road. Plus, that oil is from the crankcase, not from inside a hot combustion chamber.
Old Apr 14, 2005 | 07:31 PM
1BADFNZ's Avatar
The car doesn't look like a mosquito fogger and doesn't burn oil between changes. Sometimes there's a puff of smoke but I figured it was just unburnt gas since I don't have cats.
Old Apr 14, 2005 | 07:38 PM
WS6FirebirdTA00's Avatar
can you see any kind of external leaks?
Old Apr 14, 2005 | 08:00 PM
1BADFNZ's Avatar
nope no external leaks, the amount of oil on the plug is minimal, just trying to be safe.
Old Apr 14, 2005 | 09:56 PM
jlrz28's Avatar
10 Second Fun Car
Correct me if im wrong but someone a while back said they ran some octane booster through that turned their plugs red. But yeah I dont think they should be dripping with oil either though.
Old Apr 14, 2005 | 10:01 PM
red plugs are actually common, sometimes it may mean the car has idled too long many times, but most of the plugs should be that way if that was the case
Old Apr 14, 2005 | 11:23 PM
Grimes's Avatar
1bad, i think you are fine. If the car dosent really burn oil, then you're safe. I just did plugs last week, and one of mine did look crappy like the last pic, but she runs like a champ, and hasn't lost any oil since last oil change (7k miles)
Old Apr 15, 2005 | 11:27 PM
WILWAXU's Avatar
octane booster will make the plugs red.
the oil I see in the picture looks normal, (antiseeze) Maybe a little to much on the last install
