Banging Y pipe solutions?
Is the only fix a solid driver side poly mount? If so, where can I find one and how much will it generally cost?
Thanks
Brandon
http://www.thunderracing.com/catalog...&sid=528#P3780
The motor mounts are another way.
Also, does anyone else have problems with the driver side on QTP Ys? Or did I just do a terrible job of installing it?
Long story short, I installed the polys, and couldn't be happier.
I said above I did a few searches and came up with answers but no pics. Why not post a link if you did the search and found it? Whenever I call a repost I at least post a link to something that is helpful instead of cluttering the thread with a useless agrivating answer that does the person absolutely no good.To the others. Thanks for the help thus far. Where can I get a single poly mount for the driver side? Or should I search for that too....
Here is the thread:
https://ls1tech.com/forums/showthrea...hlight=Mufflex
Looks like the pictures have been taken down.
I'll be installing mine on Friday, I'll take some pictures.
my QTP y banged under the center console. the skidplate or whatever you call it didn't have enough clearence between it and the merge. i fixed it with some washers.
