Poly motor mounts driving me crazy..
I took four thick washers from a truck drop hitch I had laying around and shimmed it between the trans cross member and the thickness of the washer made it drop twice as far as the tickness of the washers because the headers are mounted at the front and the angle makes it drop further!And also the driveshaft angles don't change because the tourqe arm mount drops with it ! Mabe ya can make some sense out of it!
Jason
I cant comment on poly trans mount other than to say that I hear that cause hella vibrations. Most people including myself go straight to the trans mount to replace it for several reason icluding shifter handles jumping up and down and side to side under torque. Its not the trans mount doing it though. Its the sorry excuse for motor mounts from the factory.
