bassani true duals?
Old May 1, 2005 | 08:18 PM
Redneck Z's Avatar
Well I hope the optimum length for my car doesn't change the stock location of the cats. It sucks living in california, It doesn't seem possible to come up with a header that doesn't move the stock cats, is 50 state legal and actually makes power. California just makes it too hard with all their restrictions. I wonder if california will ever change? I'm sure everyone would agree that if your car runs clean and passes smog, it shouldn't matter what parts you choose to put on your car. This is so STUPID, I wish there was something that could be done. Doesn't anyone else care?
Old May 1, 2005 | 09:50 PM
mrr23's Avatar
jba headers bolt to the existing cats.
Old May 1, 2005 | 10:05 PM
Redneck Z's Avatar
Yah, but gains are minimal. They are just so expensive for little gain. I wish there was a way to design a header with a little more length that wouldn't change the stock cat location. There are just no legal options for people in california. There just isn't enough gain with the current shorty header line up.
Old May 2, 2005 | 01:24 AM
titaniumSS's Avatar
Whats the cheapest place to find the Bassani Tru-Duals?
Old May 2, 2005 | 04:02 AM
Scoobie's Avatar
I believe the only place is Vinci at the moment.
Old May 2, 2005 | 08:47 AM
titaniumSS's Avatar
He have a website or anything? I'd like to look around and get an estimate of how much i should be saving up.
Old May 2, 2005 | 11:42 AM
lsx24's Avatar
>and here's 98t56TA dyno of him taking off his stock cats and magnaflow system and adding carsound cats and bassani tru-duals
Yea that's the graph with the midrange gains. When I was in CA there were few options for smog legal setups, in fact initially installing shorties partially because of smog and somewhat for other characterisitcs to factor in afterwards. Honestly I was suprised as the gains of the combination far from initial estimates and now I'm making as much tq as a pair of longtubes and catback. The scaling might be unusual there's a solid gain of 18 lb ft though.
Old May 2, 2005 | 11:46 AM
lsx24's Avatar
When designing a smog system separate factors adjust for running performance, not just peak numbers. For instance...some states just require an ODBCII scan, which means no converters and LTs are now legal, allows you to smog with several different exhaust configurations. CA is still the most strick area, and it's hard to overlook the placement of cats since you can see them if you look under the car. My setup dynoed the numbers below with a good tune and supporting components that I assembled beforehand so I wouldn't have to change or buy anythink additional afterwards.
Redneck Z are you planning on the comp 216/220 soon? That's an interesting formula because of the increased exhaust duration in comparison to the cams that are out already with symetric patterns. With a few degrees more duration on the exhaust (without going to far split pattern) it sounds like a great combination for short tube headers with gains at all rpm plot points...the short tubes may absorb four degrees additional exhaust duration, effectly functioning like a 216 single pattern, which should be great tq and depending on the advanced technology or may peak at or around 6200.
Old May 2, 2005 | 11:53 AM
lsx24's Avatar
From another thread, I read about a theory about the potential of short tube or stock length exhaust manifolds, and how they respond to baby cams. When I added carsound cats to my setup and then dynoed with true duals, the top end numbers were similar to the stock y and with factory cat configurations, and I don't even have a cam right now. At the time I factored in this characteristic as the stock cats and y were not a rpm constriction at the moment...in other words, I doubt that if I had removed the cats completely the numbers be very different so didn't cost any hp towards the upper rpm range before additional testing and modifications.
This theory for midrange gains could be attribited to many factors, not just peak numbers or raw gains of the flow of the exhaust. It's possible to predict the dyno numbers although this won't be as great as track time or area under the curve. Instead, the additional pull of a straight through system with no restrictions contributes to the almost 20 lb ft additional tq in the midrange (!). And the pull is a noticeable improvement over old y no doubt. Now, adding a cam that holds the exhaust duration open for just that extra length, in theory and on paper looks like a perfect tq combination for stock rpm ranges. I was lucky to have another dyno in another area to confirm some of the numbers. I don't remember the exact numbers, although in theory short tubes headers with a calculated length do not have a different top end restriction as LT headers. Amazing that I'm making about as much tq as LT headers.
Old May 2, 2005 | 11:57 AM
Redneck Z's Avatar
Yes, I'll be doing the cam once I get some 918's and pushrods. This cam worked well on a friends car that had shorty headers. It should have a broad power range, Make good torque down low and pull to about 6300. Since I begrudgingly can't/won't do lt's here, I chose this cam for my stock manifolds.
Old May 2, 2005 | 12:01 PM
lsx24's Avatar
Do you know howmuch advance it has?
Old May 2, 2005 | 12:06 PM
  #32
Redneck Z's Avatar
+4, but I'm thinking of retarding it -2 or -4.
Old May 2, 2005 | 12:12 PM
  #33
lsx24's Avatar
Well particularly because Comp XR269HR14 has two degrees built in which is one of the reasons it pulls to 63~64. I'm considering utilizing this cam in a friends car as well, not sure about the timing of the pulses or how that may help draw in additional air during midrange. However I did hear that off idle sound is slightly improved.
Old May 2, 2005 | 01:01 PM
  #34
ls1mojo's Avatar
If the actual cam already has 2* advance no need to adjust it right?
Old May 2, 2005 | 01:12 PM
  #35
Redneck Z's Avatar
I'll have to check my cam card. For some reason I was thinking it had +4 ground, but I could be wrong.
Old May 2, 2005 | 01:38 PM
  #36
lsx24's Avatar
Ok, here's some food for thought. When you modify the timing the cam, you're now talking about changing the powerband up or down, aren't you? If you have supporting components to conteract the increase in tq or increase in revs that might develop, then you're on the right track. Cam companies don't just throw things together they design the timing for the application to pick up the air velocity in a target rpm area. That's why the same cam part or same duration has different effects in different applications for different tasks.
Old May 2, 2005 | 01:41 PM
  #37
Redneck Z's Avatar
Those are good #'s redt56TA. Do you have shorties, or stock exhaust manifolds?
Old May 2, 2005 | 01:42 PM
  #38
lsx24's Avatar
You might be right...there are several versions of the cam.
Old May 2, 2005 | 04:36 PM
  #39
ls1mojo's Avatar
I see, so, although it would shift up or shift down the actual output but might run best at the pre-designed timing...without introducing any weakness or abnormalities in the valve events.
Old May 2, 2005 | 04:39 PM
  #40
mrr23's Avatar
http://www.vincihighperformance.com/...s1exhaust.html order online for the stainless @ 949.00 or call them for the aluminized at a LS1TECH offer for 799.00
