True duals over the axle out through a CME...
Old 05-04-2005, 09:07 AM
  #41
jimmy 2 Times's Avatar
Originally Posted by Swang
bmr relocator? whats bmr?
it relocates the upper pan hard bar, look at the pics in my first post, it is the red bar near the differential
Old 05-04-2005, 09:15 AM
  #42
Originally Posted by elite22xl
what did that system cost you in parts, the cost of all the pipes, bends, x pipe, and mufflers? not including the cme
i dont have a price list, (because i have been buying parts for months, so it wouldnt be too much at once, i started buying parts in august or so) but look to spend about 400-600 in pipes, x-pipe was custom made, (but magnaflow has a nice xpipe, which i bought, then decided to make my own, the magnaflow cost $84, alot cheaper than dr.gas) mufflers ran me about $90, BMR relocation $200, CME tips (i ordered new ones, because the stock one was on since early 2002) about $250, and look at about $50.00 for band clamps, hangers bolts, etc.
now, labor is antoher thing.......if you dont do it yourself, get ready to be
good luck
Old 05-04-2005, 09:16 AM
  #43
240M3SRT's Avatar
Originally Posted by jimmy 2 Times
well finally, after weeks of planning and research, my project is complete. qtp headers, to 3 in custom X-pipe, dual 2.5 in out through 2 magnaflow bullets, then to CME
sound is quiet, but with a deep rumble, inside teh car no resonance, and i can now talk with my girl in the car. definate increase in throttle response, and my "Butt Dyno" told me i pick up some lost low end torque and hp.
this system was built entirely by pre-bent pipes, then cut and welded. It has clamps on the headers, and again near the axle, so if i need to change anything, the system just drops down. Clears slp DD subframe connectors, and no lost ground clearance
here are the pics
http://i5.photobucket.com/albums/y16...5/IMG_0482.jpg
http://i5.photobucket.com/albums/y16...5/IMG_0481.jpg
http://i5.photobucket.com/albums/y16...5/IMG_0480.jpg
http://i5.photobucket.com/albums/y16...5/IMG_0477.jpg
http://i5.photobucket.com/albums/y16...5/IMG_0476.jpg
enjoy
On the 3rd pic, why is there a dent just before x-pipe?
Old 05-04-2005, 02:23 PM
  #44
I think that it is just the light....there was no dent when i bolted it up
Old 05-04-2005, 09:26 PM
  #45
That's what she said...
TheBlurLS1's Avatar
ya know, you could edit out all the pictures but the one you're referring to when you quote a pic filled post like that
that does look like a dent, and it's probably there so the TQ arm will clear better?
Old 05-05-2005, 08:43 AM
  #46
GuitsBoy's Avatar
I had to dent mine in with a big hammer, but it needed denting in two places for the subframe cross bracing. It crosses over the torque arm at the very front where the torque arm is quite small, so no denting there was required for me.
Old 05-05-2005, 09:00 AM
  #47
Pesticide's Avatar
That has to be one of the slickest setups I have seen for our cars. Kudos Man!
Old 05-05-2005, 09:01 AM
  #48
I actually cut the one part of the subframe, and moved it, then rewelded it to fit
Old 08-28-2005, 03:29 PM
  #49
ulySSes's Avatar
Did you happen to get a sound clip of this yet?
Old 08-28-2005, 05:16 PM
  #50
Heartless's Avatar
Nice set-up.... and thanks for the pics, is exactly what I'm looking for
Old 08-28-2005, 05:42 PM
  #51
Heartless's Avatar
well pennslyvania is a bit far to buy you a beer..... but I would sure like to know if you have dimensions somewhere for all your splices and pipe lengths......
Old 08-29-2005, 09:19 AM
  #52
King James's Avatar
To everyone wanting sounds MeentSS02 has some on LS1sounds.
http://www.ls1sounds.com/true_duals/...peedIncTDs.AVI
http://www.ls1sounds.com/true_duals/...ht-driveby.AVI
I also used the 4" round Magnaflows with my true duals. If you are wanting something loud and obnoxious these aren't the mufflers for you. At idle the sound is very deep. Cruising around town or on the highway they sound is very tame and mellow. At WOT the scream, but still not extremely loud. Before my LT's and TD's I had stock manifolds, stock cats, and a cutout. That system was louder and more obnoxious then my true duals, but had a real tin can sound to it. Now my car has a deep muscle car like sound to it.
Old 09-06-2005, 09:04 AM
  #53
i am still working on some sound clips
Heartless,
i will see if i still have my original measurments, and i will send them to you
Old 09-06-2005, 09:41 AM
  #54
Bryan @ Speed Inc.'s Avatar
my pants are getting tighter.......... that setup is so friggen sweet!
Old 09-06-2005, 10:15 AM
  #55
Trev_SS's Avatar
congrats man that is awesome work!
Old 09-06-2005, 10:18 AM
  #56
Kleeborp the Moderator™
MeentSS02's Avatar
Damn...I need to get some new videos with my new wheels on...my car is finally tuned as well. It never ends
Old 09-06-2005, 11:14 AM
  #57
AronZ28's Avatar
That is an awesome setup And there isn't an issue with ground clearence?
I still do not understand why an aftermarket company hasn't made a true dual system that goes over the axle. If they crank out 10,000 of them bad boys a year, I'm sure the price would be a lot less than your $1500 hand fabricated masterpiece.
Old 09-06-2005, 11:20 AM
  #58
MeentSS02's Avatar
Nope...no real issues with ground clearance. With my new wheels and tires, I gained back another .75" since I went to a taller tire in the back.
I have scraped it before, and it only does it on the driver's side just after the header, but there isn't much that can be done about that area.
Old 09-06-2005, 11:45 AM
  #59
AronZ28's Avatar
I see you are in nice and flat Ft. Walton Beach(are you in the Air Force BTW?). I just don't know about being here in Tennessee with all the hilly and steep driveways.
Old 09-06-2005, 11:51 AM
  #60
MeentSS02's Avatar
Yep...definitely in the Air Force. And if I've scraped it anywhere, I've scraped it in one of our few steep driveways...sucks to hear that sound.
Quick Reply: True duals over the axle out through a CME...
