TSP Dual install question.
Old Apr 27, 2005 | 01:24 AM
SilverM6SS's Avatar
Default TSP Dual install question.
On a stock height F-Body how far from the ground is the lowest part of the system? How did you deal with clearance of the torque arm? Is anyone using TSP duals on a lowered car?
Thanks,
Joe
Old Apr 27, 2005 | 01:28 AM
psykoTA's Avatar
People are, and their clearance IMO sucks. If you search, there are all kinds of threads, and I remember seeing lots of pics.
Old Apr 27, 2005 | 10:05 AM
Z-286speed's Avatar
The clearance on stock height is not bad at all. Just take the speed bumps kind of slow, and you should be fine.
Old Apr 27, 2005 | 01:11 PM
ss2000's Avatar
i got them and my car has eibach pros. i don't have a problem scrapping the ground, but the clearance with my bmr torque arm is none.
Old Apr 27, 2005 | 03:57 PM
kraut187's Avatar
Here's my stock height SS Just have to go slow on the speed bumps, They can tuck up more, but have to adjust the brake lines and such.
Attached Thumbnails TSP Dual install question.-dsc00490-small-.jpg   TSP Dual install question.-dsc00491-small-.jpg
Old Apr 27, 2005 | 05:05 PM
Silverhawk_02TA's Avatar
No complaints here. It's all about taking your time and getting those bullets tucked up into the tunnel. Clearance around my torque arm is enough to get my finger in between.
Attached Thumbnails TSP Dual install question.-2.jpg   TSP Dual install question.-3.jpg   TSP Dual install question.-4.jpg
Old Apr 28, 2005 | 10:08 AM
jj_z28's Avatar
I have Eibach sportlines and barely ever rub. I have a BMR torque arm and there is about a finger of clearance between it and the x-pipe. There is about a half of a soda can of clearance at the bottom of the turndowns. I also recently redid them and turn the bullets out and it as less drone and more clearance.
Old Apr 28, 2005 | 10:09 AM
jj_z28's Avatar
Only complaint is the driver side bullet is tight to the torque arm.
john3daly's Avatar
Those turndowns are purty...mine are flat on the bottom.
