slp lt to tsp's true duals?
Old Apr 27, 2005 | 05:26 PM
tensecls1's Avatar
Default slp lt to tsp's true duals?
just wanted to know if this set up will bolt up. Because i think the slp headers hang lower then the pacesetters and have a slightly different bend on the drivers side ( or what it looks like from the pictures).Thanks for any help guys
Old Apr 27, 2005 | 05:54 PM
SuperZ's Avatar
I wouldnt do the slp's if i where you i have them and they hit things that shouldnt evan come close to scrapping.I actually just ordered pacesetters.
Old Apr 27, 2005 | 07:33 PM
blkZ28spt's Avatar
Stay away from the SLP's. That's what most people on this board will tell you. They are expensive and hang low. For cheap headers get pacesetter, middle range hooker or jet-hot, little better and nice options like removable cats and straight pipes get FLP and the cream of the crop are stainless QTP's and Kooks.
Old Apr 27, 2005 | 07:39 PM
tensecls1's Avatar
i already have the slp's in the car, i just want to know if the tsp setup will connect to these headers.
Old Apr 27, 2005 | 07:41 PM
sh33p4u's Avatar
not without some modification, bolted right up to the pacesetters though.
Old Apr 27, 2005 | 07:51 PM
CATCH ME's Avatar
sell the SLP's and get some pasesetters. i have the SLP's and duals and it was a pain in the *** to get my duals put on. they aren't TSP duals but they are from a non-sponser . when u get them on it will be sweet. btw: im switching out my SLP's for Kooks or QTP's
Old Apr 27, 2005 | 08:19 PM
tensecls1's Avatar
i know the pass side will be okay it's the drivers side that i am worried about the bend on the pipe that connects to the header. Or is there an off road y pipe out that will connect to the headers and run a cat back system
Old Apr 27, 2005 | 09:54 PM
crizain's Avatar
For catch me and the other guy that has SLP's, are either of you lowered with or without the duals? How streetable is it? Sorry for hijacking your thread but I have slp's and want to lower it but I am sick of people telling me to get rid of them. The fact is they make freakin power for me and I like them...
Rob
Old Apr 27, 2005 | 10:33 PM
FormulaFire's Avatar
I love my SLP's.. They kick *** and I would put them against any other header.
Old Apr 28, 2005 | 01:21 AM
Casperws6's Avatar
Old Apr 28, 2005 | 05:25 AM
DD966's Avatar
Rob
Get under your car and measure the clearance from the closest point to the ground (mine is just under 4"). Then take into account how much you plan on lowering it (I'm assuming 1 - 1.5"). If you can live with that - do it. If not ... I have no plans on lowering mine. Good Luck.
Old Apr 28, 2005 | 10:38 AM
tensecls1's Avatar
does anyone know if lanes can make a dual setup for the slp headers? I just read a couple of previous posts on how they hug the floor board of the car and have almost no ground clearence loss on stock height cars.. and that they are a very good setup.
Old Apr 28, 2005 | 10:47 AM
CATCH ME's Avatar
crizain: i am lowered 1 1/4 with the headers and yes they scrape some, its not horrible but i have to be careful to not scrape on everything. my passenger side header has a large scrape in the pipes bofere the collector and i dont think that it is a wise decision to get the car lowered w. SLP's.
tensecls1: my set up is a lanes duals set up and what he did was make up his kit like he normally does and then sent me a J-pipe to complete it. i took the exhaust to a shop in Tampa and he made up the rest of the system from scratch. it was not that bad once he figured out what he was goin to do but up till that point it was a pain in the ***. my duals dont scrape the headers scrape!
Old Apr 28, 2005 | 07:32 PM
tensecls1's Avatar
so the lanes is pretty much bolt in? I really don't want to weld any thing in yet
Old Apr 28, 2005 | 07:36 PM
jrp's Avatar
jrp
SN95 Director
i know for a fact the TSP wont bolt up w/o any modifcations. i did the reverse, a while back bought a set of duals that were made for a set of SLP's and i have jet hots. the angles are different which you could clearly see when compared to my Y pipe made for my jet hots.
Old Apr 28, 2005 | 07:39 PM
jrp's Avatar
jrp
SN95 Director
no its not "pretty much bolt in", catchme stated that lanes sent him a generic J-pipe which will need to be cut and fitted to get the correct angle to mate up with the collector and then to the rest of the tubing. welding will be required.
Old Apr 28, 2005 | 11:34 PM
tensecls1's Avatar
what where the mods that you did to the tsp setup to make it fit
Old Apr 29, 2005 | 05:18 AM
FHAWK02's Avatar
Default The Key to SLP's
In other words if you are planning to get SLP's do not lower your car. But if you are not going to lower then get SLP's, (never had a problem scraping with mine)
