Need Advice
Old May 3, 2005 | 10:29 PM
uLoSeAgAin's Avatar
Default Need Advice
I got in my car the other night and when I drove it for about 3 miles got out and got back in started it up...I notcied the exhaust note was non existant. So I hit the gas real quick and I got a back fire and stumle so I did it again thinkin maybe I just hit it a lil too much too quick and threw off the car a lil and it did the very same thing...once I got it in gear and going like sub 20mph the car stumbled badly especially idling almost chocked down. Went 3 days with no problems since, but today I went WOT on the way home and at about 75 to 90 I felt like a slight hesitation/stumble that was almost like a slight slight jerking. I couldnt figure out if maybe like the injectors crapped out, spark plugs, spark plugs wires, or something else I havent figured is the problem. Any help or suggestions would be much appreciated.
Old May 3, 2005 | 10:47 PM
RPM WS6's Avatar
LS1Tech Administrator
Community Influencer
Getting an SES light?
Do you have any sort of PCM scanning tool to check for misfires, KR, etc?
You could check/change the plugs/wires and fuel filter as pretty easy first steps.
Old May 4, 2005 | 12:11 AM
snake charmer's Avatar
i would pull the plugs and look at them first maybe change them while you are at it, plug wires check them out good.
