Just got a Flowmaster
Old May 11, 2005 | 12:48 AM
jaberwaki's Avatar
Originally Posted by dajodsterman
Your very correct and yes it is a 40 series. The one on my car is single in, single out with an offset that has been modified. The stock pipe is welded to the inlet of the muffler. A new piece of pipe was welded to the outlet on the drivers side with a tip. IMO a muffler with one outlet on an otherwise stock exhuast works just as well as a muffler with one inlet and dual outlet. Unless of corse you modify the muffler that has one outlet. Also one tip coming out the back of a T/A would be rice cake city. So to add another tip would be a good idea, making it functional would be an even better idea. To do this the shop cut another hole on the inlet end of the muffler. Welded on a flange and welded to that another piece of pipe with a tip coming out the passenger side. There you have it, good ol southern enginering. And now that I'm thinking about it, the extra tip on the inlet side would probably help with flow if there was backpressure in the muffler. I do know for sure that it has a unique deep smooth sound to it. Also any concerns with flow could be solved by un-capping the cut-out. I feel like I got my money's worth and besides what's a muscle car with out a little bit of that southern enginering.
Thanks for your concern and what a great eye on noticing that about the 40 series Flowmaster.
thanks for clearing that up....
sounds like a good setup you got there...
Old May 15, 2005 | 03:10 AM
Redneck Z's Avatar
QUOTE: a friend of mine has a flowmaster on his LT1 Z28 and it sounds awsome, i called Speed Inc. to get myself one, Larry told me that he wouldnt recomend it
Alot of mufflers sound good on the LT1, and sound like crap on the ls1. The LT1 is a totally different car than the LS1, and you can't even compare muffler to muffler on the two cars. It's like comparing the sound of a flowmaster on a 4.6 mustang vs. an LS1....totally different. The LS1's I've heard with flowmasters and stock exhaust manifolds sound like a V6. IMHO, it sounds like your runnin around with your tail between your legs. No offense to you guys who run them, it's just my personal opinion.
Old May 15, 2005 | 05:56 AM
jaberwaki's Avatar
you MUST be talking about the 80 series...
the 40 series sounds good...
Old May 15, 2005 | 07:35 PM
dajodsterman's Avatar
Just as you say your can't compare the same muffler on two different cars, you also can't judge that a 40 series sounds "like crap" just cause you've heard the way a 80 series cat back sounds. There made by the same company but the're totaly different mufflers. Go to the Flowmaster web site for your self. Look at the diagrahms of the inside of the two mufflers. The size is way different. The internal design is different. Just like the diffrence between the 4.6 mustang and the LS1. Dude I wish I had a way to make a sound clip of my set up and send it to LS1 sounds. You wouldn't be saying it sounds like a v6 and surely not with its tail between its legs either. Oh yeah the manifolds are stock. And in case you haven't read the whole thread I'm not the only one that likes the 40 series.
