NO! header bolt!
Old May 8, 2005 | 06:11 PM
TJ's Avatar
TJ
Default NO! header bolt!
drivers side rear(last) bolt. got them all in and turned them in a lil at a time to pull the gasket up even. tightened them all down, but the back bolt is about 3/4 of the way in and just stopped all of a sudden.
it will not budge, i cant even get it loose now. i have no idea what happened. started fine, wrenched it in with a 10mm ratchet wrench and all is good. im screwed.
anyone ever run with a rear header bolt out? think it will leak? its on a stock maniold if that matters.
grrrr.
Old May 8, 2005 | 06:20 PM
01350ss's Avatar
it will leak. try to get it out
Old May 8, 2005 | 06:37 PM
cyphur's Avatar
it'll definitely leak.
Old May 8, 2005 | 07:26 PM
TheBlurLS1's Avatar
That's what she said...
did you use never-cease on them?
try and get it out best you can, it may be a bitch, but you really need to try. after you do this, you can try and run a tap into the hole and clean the threads, then probably have to get a new bolt, and make sure you use never-cease. its the best stuff in the world.
Old May 8, 2005 | 09:32 PM
shep28's Avatar
that is strange. I had to do some work on my car and I had to take the driver side header off. That last bolt gave me problems. I ended up taking the bolts off and installing that rear bolt first half way and then the others. I found that I had to wiggle the headers as I tightened that rear bolt. I think the bolt teeth were getting caught on the metal header gasket.
Old May 9, 2005 | 12:02 AM
rush7's Avatar
last bolt driver's side gave me all kinds of problems on my install. It doesn't leak but I pretty much forced it in there and it's not going to be fun to take out if I ever have to.
I'd be pretty much with everyone else saying your headers will leak w/o the bolt in its place.
Old May 9, 2005 | 01:30 AM
quickWS6's Avatar
I cross-threaded that bolt. I never fixed it and I've never had any leaks.
