diagnose electrical gremlin
Old May 10, 2005 | 01:33 PM
Wnts2Go10O's Avatar
Default diagnose electrical gremlin
i installed a shift light into an 01 ss and used the 12v from the radio. sometimes it will trip a circuit breaker or something, because fuses dont blow and it will start after a few minutes. i can find a short or nething. help?
Old May 10, 2005 | 09:53 PM
wrencher's Avatar
wrencher
What a sec, do you have a no start or a no crank problem now after the shift light install?
Old May 10, 2005 | 10:01 PM
WS6FirebirdTA00's Avatar
i tapped my shift light into the fuse pannel, how is this thing hooked up?
Old May 11, 2005 | 12:48 AM
Wnts2Go10O's Avatar
i soldered it to th eradios 12v power line. and ocasionally when i go to start it everything shuts off. i havent seen any signs of a short and its grounded well so.. im stumped. it goes :click: then nothing... 5 minutes later it starts up fine and no fuses are blown and everything works fine.
Old May 11, 2005 | 08:21 AM
hmmmm, i would try to undo that wire and tap in the fuse pannel and see if that helps anything
