electric cutout
Old May 11, 2005 | 11:10 AM
cjels1's Avatar
Default electric cutout
after having an electric cutout installed where should i runthe wire thru to the cabin?: like under the shifter or what... also where does the wire connect to some sort of power source to open the mechanism?
Old May 11, 2005 | 11:19 AM
Diolar Magnum's Avatar
RIP April 14, 2008
From: the land where cars repeatedly hit my bumper when I'm in the store...
the search button is your friend, my friend.
https://ls1tech.com/forums/showthrea...t+installation
Old May 11, 2005 | 11:21 AM
2001NBMZ28's Avatar
Route the wire into the cabin by removing the right rear bottom seat cushion, you'll see a grommet there. I used the black wire off the cig lighter for ground, and extended the power wire and connected it to my radio fuse. You can also get power from the pink wire behind the traction control switch.
Old May 11, 2005 | 11:47 AM
cjels1's Avatar
does the QTP cutouts usually come with wiring long enough to go up thru the seat drain plug, into the armrest? then up to behind the TCS switch for power from the pink wire?
Old May 11, 2005 | 12:16 PM
2001NBMZ28's Avatar
There's plenty of wire to mount the switch anywhere you want. I used a butt splice to extend the power lead off the switch so I could route it under the carpet to the radio fuse. Very easy install, and comes with a good set of instructions.
Old May 11, 2005 | 04:56 PM
SmaknaSS's Avatar
I routed mine through the shifter grommet.
