power steering?
allready bled and did that, then filled it back up, and it's been 2 days now and there is still a slight groan and vibration when I get near locking it each way. Just seeing how long it usually takes for that air to get pushed out of the system so it'll stop groaning
then replaced it w/new power steering fluid (the right kind)
now when I drive the PS groans and vibrates slightly, most likely to air trapped in there, so I was curious as to how long it takes usually for all the air in the system to be pushed out (as far as I know, the air will be pushed out by driving it daily)
Maybe the pump is on its way out. Usually doesn't take very long for the air to bleed out. After a drive or two the air should be out.
I'm guessing the fluid was topped off in the first place because of the groan.
Let it go. If the groan becomes serious then look at replacing the pump. I don't think they are too expensive and you already know how to change it.
mebbe in for some mangias
Time you get off work?
it was on the lift, unhooked the lines goign to the rack, let it drain, then after it slowed, turned the wheel lock to lock and more drained, then when it was done, put it back on and filled it back up
for the most part the groan is gone, but now there is a little little bit when I get close to lock to lock.
off @ 6:11
off @ 6:11
the car wasn't running :dunno:
how else would you get all the fluid out?
