Help! power loss after installing lingenfelter intake
I have a 98 z28 a4, I just installed a lingenfelter intake manifold and a volant cold air intake, but the problem is that as soon as I installed the intake the first time it hat a really rough idle and would accelerate really high then turned of, so I automatically knew there was a vaccum leak.So I took off the intake and put it on again,this time I calibrated the screws to tightened at 16ft/lbs like it said on the instructions and had my mechanic help me do the install.Well after the install the car sounded normal so I took off the plug on a sensor which I guess is the speed sensor that goes connected to the tb, and all of a sudden the idle went to about 2500 while the car was parked.I then took the car for a run for about ten minutes and it responded really well , but when I took it on the freeway I took it on the freewsy doing sbout 100mph, I then noticed that the car lost alot of power, so I got off and went through some smaller streets and the car picked up well from 2nd to 3rd gear doing about 30mph but then I noticed that it will take a while for the car to pick up speed after I was pressing on the gas and rpm's were high to about 3500, so I knew something was wrong same thing on the freeway, I pressed on the gas till about 4000 and the car will barely feel like picking up speed, but if I stomp on the pedal all the way down it'll respond like it's suppose to.Can someone help me on what this problem could be.THANK YOU
well I didnt unplug it my so called mechanic did, but plugged it back in after the idle got higher, I didnt know I have tune the manifold and how do i tune it
