BBK 80mm TB..
Old May 14, 2005 | 12:33 AM
blkhurstz28's Avatar
Default BBK 80mm TB..
recently got my bbk 80mm throttle body, and installing it i had a little problem. After i installed it the car wouldn't idle properly; the rpm's kept rising until i took my foot off of the clutch and the car was in neutral. The pedal was also pushed all the way down to the floor, and all i could do was push the top of the pedal...what did i do wrong?!
Old May 14, 2005 | 03:38 PM
lsx24's Avatar
Check the idle setting. Make sure of two things: there is nothing to resist binding and the idle **** is smooth at a consistant ~850rpm.
Old May 15, 2005 | 12:15 AM
k thanks ill try that in like 2 weeks.....finals...no time...
Old May 15, 2005 | 10:26 AM
SouthFL.02.SS's Avatar
!LS1 11 Second Club
Sell that BBK and get yourself a ported stock TB.
Old May 15, 2005 | 07:43 PM
why...?
Old May 15, 2005 | 07:52 PM
99CamaroSS_'s Avatar
bbk is a crap tb, they have a lot of problems not to mention they dont flow that well. You would be better of with selling that one for 300+ and picking up a ported stock one. just my .02
Old May 15, 2005 | 09:14 PM
i bought it for 250...
and i wish i knew this before i bought it
Old May 15, 2005 | 09:15 PM
what mm are the ported stock ones!?
Old May 15, 2005 | 09:21 PM
tripps's Avatar
Bo white did his at 75 mm, but hes not porting anymore. If u ask around with your local F-body friends/clubs, they will know of someone that ports.
Old May 15, 2005 | 09:48 PM
what do the stock ones start out as?
Old May 15, 2005 | 09:53 PM
Tom the roofer's Avatar
What exactly IS the lots of problems you are talking about? I used this exact BBK ported TB for 2 years and had exactly NO problems with it. Check my sig. I ran that ET and MPH N/A with that BBK TB he bought from me.
Just wondering.
Old May 15, 2005 | 09:56 PM
Just wondering.
well like i said earlier..it was wierd, the pedal was pushed down to the floor, and the only play i had in it was when i pushed the top of the pedal and it only went down like an inch. the normal position of the pedal was about 3 inhes forward.
Old May 15, 2005 | 09:57 PM
did you adjust the idle setting or anything else after you got it?
Old May 15, 2005 | 10:03 PM
Did I? Well yes I did adjust it to my cars needs. There is nothing wrong with that TB. Sounds like you have a bind in your throttle cable.
I also responded to your PM and asked you a few questions.
Old May 15, 2005 | 10:07 PM
!LS1 11 Second Club
What good is an 80mm TB on a stock LS6 intake? I've read many BBK TB issues over the years. I've read of zero problems with stock ported TB's.
Old May 15, 2005 | 10:08 PM
o sry i forgot to reply to that,
yes i hooked up the sensors..no i didnt change the pcm, but shouldnt it just throw a code at most and nothing else?!
Old May 15, 2005 | 10:11 PM
I had 0 problems with the 80mm BBK. Besides, I sold the man what he asked for. I have NO idea what his set up is.
Old May 15, 2005 | 10:12 PM
btw its a stocker right now...
Old May 15, 2005 | 10:13 PM
I also have a ported stock TB that stuck open on me once. You must have been lucky to get a good stock ported TB.
