youd think for $1000 youd get headers that wont lay on the damn kmember
Old 05-17-2005, 01:34 PM
!LS1 11 Second Club
SouthFL.02.SS's Avatar
Originally Posted by 8GTOKLR
Common guys this isnt a ford we are talking about you dont rig it lol. The header company should be some what responsible cause they do include research and development in their price...I would bitch but leave them on. I would also email them the picture
This is not common with KOOKS. KOOKS and QTP = the best money can buy.
It's gotta be an isolated case.
Old 05-17-2005, 01:57 PM
00Z28 Camaro's Avatar
hm , mine dont do that i dont think ? now im going to go check
Old 05-17-2005, 03:55 PM
Tally TransAm's Avatar
aint my car so i aint worried about it, and i sure as hell aint taking them off
Old 05-17-2005, 05:21 PM
noah89's Avatar
I'm headed to the garage to look at mine now.
Old 05-17-2005, 05:27 PM
OldeSkool's Avatar
Ummm... was everything back in place when you noticed this/ took the picture? For example, everything tilts down when you undo the trans crossmember because the motor mounts flex... if you havent bolted the trans back up yet, try it and hopefully everything should clear fine.
Old 05-17-2005, 05:32 PM
cyphur's Avatar
mine used to do that with the stock catback. but when i installed GMMG for some reason they don't touch anymore(kooks weren't moved for the install). i also know my motor mount is bad and there are plans to fix it soon(if i get off my lazy *** for a day). they fit GREAT before my MM went bad. i'd definitely look into that.
Kooks do fit well....but keep in mind they were probably designed around a car w/good motor mounts
Old 05-17-2005, 06:24 PM
APeteSS's Avatar
as for the situation has the car ever been in an accident of any sort? If not send em back.
That's what I was thinking. Sure the car is straight?
Old 05-17-2005, 06:30 PM
car is 100% straight with like 8k on it so it aint the motor mounts. the car was actually CT Morgan's old car that was on the cover of gm hightech performance.
when the picture was taken everything was tightened, buttoned down, ready to go.
Old 05-17-2005, 06:48 PM
Scully's Avatar
i just purchased a set of kooks 1 3/4 lts. they should be here by the end of the month. has everyone that has installed the kooks had this problem? just wondering to see if i should send them back and get something else.
Old 05-17-2005, 06:51 PM
!LS1 11 Second Club
In the 2+ years I've been on this site, this is the 1st I've seen of this. You bought some good headers.
Old 05-17-2005, 10:46 PM
ramairws6's Avatar
Talking Headers
First post ever on this forum! Always lurking though. I installed a set of 1 7/8 Kooks about a week ago and had the exact same problem on the same side. I just figured when you have such tight tolerances you can expect to do alittle tweaking?! Oh well, I just heated this spot up slightly and put my own little slight bend in so it doesn't make contact. I have all the polly mounts so when the engine torques it doesn't move one bit
Old 05-18-2005, 09:47 AM
  #32
SLPSS01's Avatar
Someone posted last week complaining about Pacesetter's, I remember a few comments "you get what you pay for". My Pacesetter's went in with no clearance issues whatsoever.
Whether you spend $1,000 or $375 on headers there's never a gurantee they are going to fit perfectly. Sure does suck when you fork out that kind of cash you would expect better quality & fittment.
Old 05-18-2005, 10:36 AM
  #33
Kleeborp the Moderator™
MeentSS02's Avatar
Kooks here, no problems with fitment (1 3/4" primaries). As stated though, when you start modding these cars, there is no guarantee that everything will go as planned. That is the risk we all take.
Old 05-18-2005, 12:55 PM
  #34
Dustin Butts's Avatar
I bought my Kooks 1 7/8" headers over a year ago and they touch the stock k-member also, same location. I called Kook's about it and they basically made me feel like they thought I was lying. Never did get a fix from them. I now have a tubular k-member ready to install so ....
Old 05-18-2005, 01:05 PM
  #35
guess it aint the first one then. . .
Old 05-18-2005, 01:08 PM
  #36
lsevenl's Avatar
That is my car in the picture.
I emailed kooks in hopes that they will make some effort to rectify the situation. Obviously this is not the first occurance. I find this grossly unacceptable for a company of their reputation and a part that cost this amount of money.
Old 05-18-2005, 02:22 PM
  #37
cyphur's Avatar
i've seen cory's car. he had headers on it and they fit fine. PM him and see what kind they were. however, he didn't have a cheap piece on that car(i know, i have his CM spohn lca's). i'd still check the motor mounts.
Old 05-18-2005, 09:20 PM
  #38
Dal1as's Avatar
I had a similar issue with Jet Hots. What was interesting when comparing another 02 WS6 with mine who did not have clearance issue is that our K-members weren't exactly the same. I'm guessing the tolerences of the K-members made by G.M. were quite loose and are party at fault for the erratic issues people are having with Headers.
