How do you take out the oil check tube
Old 05-22-2005 | 03:32 PM
Wnts2Go10O's Avatar
Default How do you take out the oil check tube
how?????
Old 05-22-2005 | 03:45 PM
markp03's Avatar
there is 1 bolt you take out...then pull lol...it might help to take the dip stick out first...
Old 05-22-2005 | 04:12 PM
cyphur's Avatar
there's a bolt right above where the headers connect, its a largish type. since the first time i removed it i've just hand tightened it so I can remove it easily, its not worked itself loose yet and I have bad motor mounts.
Old 05-22-2005 | 05:54 PM
Tally TransAm's Avatar
you gotta pull hard if its the first time coming out
most of the time i have to wedge a screwdriver under the dipstick tube bracket and the cylinder head and use it as a pry bar
Old 05-22-2005 | 06:15 PM
LawmanSS's Avatar
My dipstick tube comes out very easily...as the others have said, just remove the bolt and pull it right out...Putting it back in can be a little more challenging...unless you have a helper to assist with guiding it back into its hole.
Old 05-22-2005 | 06:17 PM
Lithium's Avatar
SSU's Drunk Typing Whore
A helper is a must to get that thing back in there
Old 05-22-2005 | 07:05 PM
2001NBMZ28's Avatar
