Squeaky belt
Old May 25, 2005 | 10:50 PM
ssheets's Avatar
Default Squeaky belt
Mainly noticable at low rpms. Mainly when you shut it off ... you can hear it a little at idle.
Any suggestions to quiet the chirp chirp????
Old May 25, 2005 | 11:14 PM
SgtB's Avatar
If it is a belt, then cgange it but make sure it isn't the idler pulley.
Old May 25, 2005 | 11:20 PM
RPM WS6's Avatar
LS1Tech Administrator
Community Influencer
How can you be at idle once you've shut it off? I don't get it?
If you mean the noise is immediatly after you shut the motor down for a few seconds, that may be the fans. Mine did that on the WS6. I don't think it's an issue really.
If you mean that the noise is only at idle with the car running, it could be anything from the belt, to the tensioner, to the idler pulley.
Good luck.
Old May 26, 2005 | 04:50 PM
ssheets's Avatar
Good luck.
When you turn the key off the motor makes one or more revolutions until it actually stops. It is those shut down revs when you really hear the chirp. It is also barely noticable at idle. Sounds like a classic belt squeek, I didin't think about the idler pulley, the car has just over 30,000 miles on it
Old May 27, 2005 | 04:03 AM
JGA's Avatar
JGA
Hi
The belt is easy to replace and do that before the idler. If it still squeeks then do the idler. Install University has a good instruction on replacing the idler. My car did the same thing and a new belt fixed it.
JA
Old May 27, 2005 | 11:39 AM
USMARINE1108's Avatar
Just to make sure it's not the belt, but a LITTLE BIT of vasoline on it. That will quiet a squeeky belt down.
Old May 27, 2005 | 07:45 PM
BOBA_VETT's Avatar
It's the belt tensioner.
They're known to go. I had to beat the crap out of my local dealer, taking the car to them 3 times. The final time, I told them, "look, it's a TSB, do you really want me to go find the #?!? I'm already pissed that you guys just lube the damn'd belt when I bring it in here! Don't make me go get the number!"
They didn't. Then, called me back, as if *they* had discovered the cause and replaced the tensioner.
Chodes...
Old May 29, 2005 | 02:19 AM
ssheets's Avatar
Chodes...
Great, my warranty expired last Sept. I wonder if it's the same tensioner on my 03 5.3 in my Suburban? I could swap em and then... (like that would be worth the effort
Old May 29, 2005 | 09:24 PM
BOBA_VETT's Avatar
Dammit, I can't find the damn'd TSB...
I'll see if I can drum it up for ya...
Old May 29, 2005 | 11:02 PM
RPM WS6's Avatar
It's not *always* the tensioner or the idler pulley. Sometimes it is just a belt. Just went through this issue on one of my cars, new belt was all it took.
