harmonic balancer bolt.
Old Jun 7, 2005 | 10:22 AM
chpmnsws6's Avatar
Originally Posted by 2xLS1
Then be prepared to keep losing bolts. With a long enough cheater bar, the bolt can be turned 140* easily. I use a 3/4" drive breaker bar with a 3' piece of pipe. I actually have to be careful not to go past 140*. I use the Kent Moore F/W locking tool also. On over 25 cam installs, I've never had a crank bolt come loose.
we've done ALOT of pulleys with NEW bolts and none of them have come out
Old Jun 7, 2005 | 12:50 PM
DanZ28's Avatar
I believe the 37 ft.lb. then 140* turn is about equal to torquing it to 240 ft.lbs, someone correct me if I'm wrong. I've been doing it that way for 5 years now with no issues and I always used a new bolt. I always first torque it with the old bolt, then put the new one in and Torque it.
Dan
Old Jun 7, 2005 | 02:29 PM
chpmnsws6's Avatar
thats what the local shop does without a single problem
Old Jun 7, 2005 | 03:08 PM
777's Avatar
777
Originally Posted by ss rally red
I dont know how much the ARP bolt is but make sure you have a 12 point socket when you install it........
by the way my cost on the GM bolt is 2.76.
also not the same size socket either...it's a couple mm bigger
Old Jun 7, 2005 | 03:18 PM
chpmnsws6's Avatar
seems like all of the ARP bolts i've dealt with are like that. better clamping force or something?
Old Jun 9, 2005 | 07:46 PM
rush7's Avatar
I used a 1-1/16 socket for the ARP bolt install...didn't know it was supposed to be metric...but yeah, you have to use a 12-point. I had to go buy one for 6 bucks at Lowe's
Old Jun 10, 2005 | 09:58 PM
lsx24's Avatar
Originally Posted by Red99TA
The bolt is designed to stretch when you put that final 120 degree turn on it when tightening down. As a result once it's removed you need a new one. They're called torque to yield bolts b/c you're taking the bolt to it's yield point and it has permanent plastic deformation after that (it's stretched).
Sorry for the delay, I was referring to the arp bolt, which is not tq to yeild. The stock bolt is supposed to stretch when it is tq'd correctly, even if it's a new one. The difference between the two is minimal other than the arp can be removed and reinstalled at a later time if desired.
