Gauge install help!
The senders act as a resistor in the circuit. If the gauge sees full power, then it's like the sender is sending max signal. You probably wired the power back "around" to the gauge or pinched the wires somewhere.
Samething happened to me when i installed a trans temp gauge. Look the wires over real good, i bet the cover has stripped from a wire somewhere and is touching the body (firewall maybe).
Pull the H2O pump, drill a hole right in top, tap for the sensor, and reinstall. It's THE MOST accurate place you can put the sensor. Have a link for pics, as I did this on my car. http://community.webshots.com/user/schantin Pic of the sensor installed on the 1st page. The sensor itself is tapped into the top of the water pump, next to the throttle body cable.
