"sealing" airbox to the hood
Old Jun 8, 2005 | 09:42 PM
WS6FirebirdTA00's Avatar
Default "sealing" airbox to the hood
well i took my old baffle from the inside of the hood and cut it up and used existing holes, right now its zip tied until i can get some nuts and bolts to fit right that are all the same size. i used some rubber stripping i found at work and it works great. i also put a piece of weather stripping under the air box to seal the underside off to any crap getting in from there. i dont have a pic of that though.
Old Jun 8, 2005 | 11:42 PM
JBIRD02's Avatar
looks pretty good so far, keep us posted!
Old Jun 9, 2005 | 05:02 AM
thanks, ill get pics once i get it done, ill have the bolts and nuts black so u cant see it. i like it so far, at first i was afraid it was gonna be too shitty
Old Jun 9, 2005 | 09:40 AM
obZidian's Avatar
looks good, realistically, have you seen or felt any difference?
This seems like a good idea....i have an ultra z hood and the opening where the air "rams" into the box is like an inch tall. I thought about cutting the lid open so when the hood closes, it is sealed, like your design.
Do you think i should seal the bottom as well?
Old Jun 9, 2005 | 01:58 PM
havent drove it yet, dont see much of a diff. maybe just more constant temps, little more air pressure at speed that builds up, but i doubt ill see noticable gains, but hey every little bit helps
Old Jun 12, 2005 | 04:23 PM
ive got it all done now, ill get some pics up, turned out pretty good i think
Old Jun 12, 2005 | 04:26 PM
i have also seen a steady reading of 98 kpa with a very short wot run where before it was staying more at 97, not sure if this is a result of this or not but i like to think it was lol
Old Jun 13, 2005 | 07:05 AM
No Juice's Avatar
 Michael S. Palmer
Old Jun 13, 2005 | 08:31 AM
forgot to put up pics last night, ill try and remember when i get off work lol
Old Jun 14, 2005 | 08:38 PM
ok got some new pics...just gotta finish cleaning it up a little
Old Jun 15, 2005 | 06:15 AM
No Juice's Avatar
Which baffle did you use? The one closer to the motor?
Old Jun 15, 2005 | 08:32 AM
yeah thats the one i used
Old Jun 15, 2005 | 08:37 AM
No Juice's Avatar
Can you post a pic of what you did to the air box?
Old Jun 15, 2005 | 11:11 AM
yeah man i forgot all about it, it wasnt much, but ill try to remember to do it when i get off
