LT Headers with 02 sims but SES still on?
Old Jun 10, 2005 | 12:58 PM
ls1650's Avatar
Default LT Headers with 02 sims but SES still on?
hey guys i just got lt headers installed on my 00 z28, a4 with the o2 sims n extensions n i still see the ses light comes up. im sure a lot of ppl asked this question but i want to know how can i find the code for it? im planning to go to autozone n use a scanner to find out the code but i dont know how to use the scanner so can someone please give me a procedure in how to use the scanner and figuring out what is the code for the problem. i dont wanna screw the car up by pressing the wrong button on the scanner. thanks
Old Jun 10, 2005 | 01:05 PM
Lithium's Avatar
SSU's Drunk Typing Whore
Its really simple, you can just have them scan it for you when you go in there also.
Old Jun 10, 2005 | 01:11 PM
jm8881's Avatar
Did you hook your air pump back up? That throws a code also.
Old Jun 10, 2005 | 01:18 PM
ls1650's Avatar
well i went to autozone n they said i have to do it by myself n that they wont touch the car so i wanna know what is the procedure to figure out the code. what do i do? i know plug the cable n turn the ignition on from there i dont know. any help guys?
Old Jun 10, 2005 | 01:41 PM
blkZ28spt's Avatar
That's messed up. I've had many codes (mostly stupid ones..) pulled by autozone. I just ask to have a code read, tell them the year/make, and somebody comes out with a scanner and reads it for me. I think you just plug the scanner into the plug, then switch the ignition to the on position and the scanner will show you the code(s).
Never done it myself though.
Old Jun 10, 2005 | 01:46 PM
Lithium's Avatar
Here is the users manual http://www.actron.com/publish/2005/0...lish_16151.pdf.
Old Jun 10, 2005 | 04:20 PM
Kirby's Avatar
Or if you can't understand it or don't have time to read them, here they are.
1. Plug it in to the port
2. Turn the key to the on position (DO NOT turn the car on)
3. Press the POWER button or SCAN button
4. Scan through the codes with the arrow buttons
5. Erase the codes
If the codes keep coming back, you need to fix or replace something. The scanner will help you figure out what is wrong with it if something is.
Old Jun 11, 2005 | 08:28 PM
ls1650's Avatar
ok i found the code it is p0135 refers to heat curcuit malfuntion bank 1 sensor 1. what does that mean? how do i fix this problem?
Old Jun 11, 2005 | 10:31 PM
2000slpss's Avatar
thats a heater circuit problem with your drivers side front 02 sensor. check the plugs and make sure none of the pins are pushed out. if thats fine then there is a problem with the heater circuit inside the o2 sensor. then you either are not getting power or ground to the heater circuit in the 02 sensor or the o2 sensor itself is bad
Old Jun 13, 2005 | 09:14 AM
Kirby's Avatar
Your O2 sensor has a heater inside it. O2 sensors only work after they reach like 600*. On a cold start, you won't be getting proper air/fuel mixture so the heated O2 sensor is supposed to correct that. It heats up quickly. Sounds like your heater went bad and you may need to replace it. Bad news is that our O2 sensors are $80. I would take it out, clean the sensor with some gasoline or carburetor/choke cleaner, and clean out the connection with some connection cleaner. The connection cleaner is an alcohol base spray that cleans but evaporates leaving no rust behind.
Try these things and if it still doesn't work, I would find a friend who has a used one that is still good. If you pull the sensor and shake it, you should be able to tell if it is bad or not. If it rattles, it is bad. Just don't let that metal washer trick you into that. Hold the washer against the sensor and then shake it. Hope this info helps.
Old Jun 13, 2005 | 09:17 AM
777's Avatar
777
I'm getting the same code. Looks like I'll be doing something when I get off work.
Old Jun 13, 2005 | 10:57 AM
hourang's Avatar
this code is usually generated by the fact that with long tubes the o2 sensors are located farther away from the engine and get less heat to them. a way to fix this is to buy the corvette rear o2 sensors, they have a better heater in them. they also have a really long wire which allows you to not need o2 extensions.
