need a creative way to take off emission tubes on header
I suppose one more option might be some JB weld, but it would look like sh*t I bet (I wouldnt do it to my car).
what about a hose clam that you can hide under the header and only see the strap with a metal/graphite gasket to seal it off? just not sure it that would seal it,i really need to take a good look at it
sweet.
remove the plug wire and its pretty empty right there, aint it?
you can get some orange heat shield material from mallory or MSD from jegs and summit.
just wrap it around your wire. that orange stuff will not burn.
ive had some laying on my y pipe for years with wires running threw them. its almost touching and its never melted.
Honestly, I agree with Cyphur about getting race style headers. But I understand you don't want to do that.
Yes, a pipe plug should handle the heat just fine (it might discolor a bit, but otherwise OK). The headers are just mild steel anyways. And the plug itself will handle the pressure no problem.
I would be careful about tightening the plug to much as someone said earlier. Also, watch what chemicals you put on the threads (like you don't want antisieze cause it will junk your O2 sensors).
Just FYI, you cant use antisieze because it has lead in it. Lead+O2 sensor =
. However, if you are real careful and only get the antisieze on the threads of the plug it may work. Just FYI, you cant use antisieze because it has lead in it. Lead+O2 sensor =
