Valve Cover breather PICS and Install HELP
Did a search, and didn't really find any straight forward answers. I thought I would post some pics to help others also.
Well i bought a AMW catch can but I no longer have the stock PVC setup, dissapeared when I did my H/C install. So I have two little K&N breathers I want to use for now until I can get another stock 1999 PVC setup from someone. Here are some pics of what I want to do.
Also, is this alright to do?
I have this in the back Driver Side valve cover, I believe u would call that piece the stock check valve right?
Here is a pic of the filter in the first pic in the Driver side rear valve cover w/ the stock check valve in the valve cover hole.
Here is the passenger side rear valve cover nipple. I want to put a breather from the first pic on here w/ out any check valve and leave the throttle body to front valve cover nipple alone.
So what do you think, would this work?
