random tech cats / ypipe + CARB
Old Jun 15, 2005 | 03:28 PM
hpjunky98's Avatar
Default random tech cats / ypipe + CARB
ok i did a search and i only got one answer, but id like to know for sure. is the random tech y pipe/ cats CARB leagal? will i have any issues with emmisions at all? heres what i'm talking about btw http://www.thunderracing.com/catalog...&vid=3&pcid=99
thanks for the help guys
Old Jun 15, 2005 | 05:39 PM
hpjunky98's Avatar
ttt anybody?
Old Jun 15, 2005 | 11:17 PM
WILWAXU's Avatar
Not likely..
Old Jun 16, 2005 | 09:14 AM
jimmyblue's Avatar
Moderator
That's some expensive pipe for a small gain.
They are pretty much stock-appearing (location
and fittings) so you might slide by the visual and
pass. I don't believe they are EO'd. I can tell you
they don't fit with a BMR K-member though they
should with a stocker. Personally I'd say, save the
money, gut & port a pair of junkers, swap those,
two Toyota oil pan drain plugs and a set of O2 sims
on every July and put the stock cats & rear O2s
back every June. Or test tubes, even better but
more rare, cheaper by far but visually observable.
The RT cats in this package flow between straight
pipe ("test pipes") and gutted cats, for backpressure
by my leaf-blower / manometer testing. They're good.
But I don't think it's $595 worth of good. Though it's
true that living in a police state raises the value (or
at least, price) of anything the least bit naughty.
I bought mine used for like $300, and gave it away
to a buddy when it turned out to interfere with the K.
Old Jun 16, 2005 | 11:54 AM
hpjunky98's Avatar
ok...god i hate living in cali
