The stock cat-back comes out without cutting after all.
I tried out the back of the car by letting the right side shock go and lowering the axle. I also pulled out the panhard bar and and the brace right above it that also crosses the car. With those out, I could not lower the axle enough to get it out. I released the sway bar on the right as well and that let me jack the driver side of the axle up which cocked the passenger side of the axle downward. Still no go.
I removed the passenger side spring and with the muffler tilted about 45 degrees (driver side down) I got the pipe to swing over the right disc brake (wheel was off). Once I figured out how it was quite easy.
So for anyone who wants to pull it out intact, its do-able. Knowing ahead of time what method works it would only add about 45 minutes to the job. Although I used a lift, the muffler was not tilted too much when it finally came out, I think tall jack stands would do it.
