horn problems
Old Jun 21, 2005 | 03:31 PM
cobrakillr718's Avatar
Default horn problems
I have a 99 Z28 and the horn buttons on the steering wheel stopped working. The horn Does Work when you press the factory alarm remote. I checked all the fuses and their all in good shape. What should I try next? Can it be the Horn Relay in the fuse box under the hood?
99 Z28 18,500 miles
Thanks in advance!!
Old Jun 22, 2005 | 11:02 AM
jam01's Avatar
its probally the contacts. if your that concerned about using the horn, go to the dealer or a good mechanic. the airbag has to be pulled if thats the problem.
Old Jun 23, 2005 | 11:15 AM
Unhappy
hey thanks, do you think i can pull the airbag out myself without running into problems?
Also the horn works when the wheel is turned all the way to one side. Strange
Old Jun 23, 2005 | 11:29 AM
jam01's Avatar
not sure, i guess it depends upon your skills and if you have the tools and know how. ive never pulled one off. im sure if you ask around or maybe somewhere on this site. good luck
Old Jun 23, 2005 | 01:26 PM
CATCH ME's Avatar
easy fix...get the bumper sticker that says horn broken watch for finger.
