overheating ?
the car sat for 3 hours and i checked the coolant level and it was ok, and the radiator was full. drove about 1 hour home ( 45 miles ) and the temp gauge was ok, around 185 like usual. got off the highway and sat in traffic, was around 207 or so, but got home and put the car in park, to put the ttops back on and noticed after i had shut it off, the temp was back around 211
i replaced the water pump last october, any ideas of what happened ?? i am going to have a tech at work pressure test it on tuesday
this sucks
i have not added any coolant. coolant was filled when the water pump was installed, that was the last time.
how about the t-stat ?? i thought it came with the new water pump, but i was told that it is in a seperate housing. where is the t-stat housing and how easy is it to change ??
i might look into the 160 t-stat. do i have to buy it from a performance shop ?
You had too much coolant in the bottle. When the radiator pumped up the cap bleed the excess pressure (and coolant) into the bottle which in turn overflowed. That's why that cap has vents. When the coolant pressure returns to normal it will suck the coolant back from the bottle. That's why the line runs from the radiator neck to the bottom of the bottle.
thanks for the replies
i think this is the right one
http://buy1.snapon.com/catalog/item....re&dir=catalog
i have noticed that the temp gauge has been going to 200-210 more often, but it has been hot. fans are operating normally. a friend of mine said that they thought they smelled coolant from my exhaust ( might be hard to tell since i have lt's no cats and an open cutout ) anyways, i have kept an eye on the coolant in the radiator and the filled neck dipstick and it has been ok. no visible leaks or any spotting on the ground.
so i had a tech pressure test it today at work and it lost pressure, inspected the car thoroughly and could not see anything, raised it on a rack and the under side of the engine is bone dry.
do the early ls1's have problems with intake leaks ?? head gasket leaks ??
i'm confused
