90mm tb setup help
Old Jun 28, 2005 | 06:18 PM
SSPerformance's Avatar
Default 90mm tb setup help
im runing a big inch ls1 with a 90mm intake , 90mm tb , 85mm MAF now my question is should i run the 75mmlid wich i have now or go to the TSP 85mm lid, if i keep my 75mm lid whats hould i use for a bellow to go from the 85mm maf to the 75mm lid
Old Jun 29, 2005 | 12:02 PM
hoserack's Avatar
Get the 85mm TSP lid so it will look nice.
Old Jun 29, 2005 | 02:25 PM
AnthonyR's Avatar
SLP sells the bellow you would need. It's not listed on the website, you would have to call them to order it.
Old Jun 29, 2005 | 02:27 PM
Steve Burger's Avatar
LS1TECH Sponsor
I got everything ftom TSP from the lid to the intake. They have a bellows that will work.
I will be installing them in the next week.
Old Jun 30, 2005 | 08:57 AM
TXCAMSS's Avatar
"All Motor 9 Second club member"
Keep us updated on the gains Steve. I'll be doing the same mods as well shortly.
Old Jun 30, 2005 | 11:42 AM
Bill's 02 Z-28 SS's Avatar
Hi Guys
I used my 75mm lid with a clamp from Home depot - I think it was a 3.5 metal clamp (clamps attached to the unit). I removed the rubber piece and attached the 85mm MAF with the Lid. The inside diameter appeared to be the same as the MAF. I just butted them together and clamped.
Bill
Old Jun 30, 2005 | 12:31 PM
CrazytrainWS6's Avatar
i got my bellow from pace. it comes in the ls6 MAF sensor package, but you could buy it separately
Old Jul 5, 2005 | 12:45 PM
LS1TECH Sponsor
Just installed the Fast 90, NW TB, 85MM Maf and lid. It all fit very well and the car started right up. It really needs a tune and I will get that at Speed Inc. on 7/15. It is running VERY rich right now. I went through almost 1/4 tank in about 35 miles.
You can hear the car breath with this setup. Sounds like a jet engine pulling air.
Will post tune results after the 15th.
Old Jul 5, 2005 | 02:52 PM
LawmanSS's Avatar
Originally Posted by Steve Burger
...You can hear the car breath with this setup. Sounds like a jet engine pulling air.
I'm running the same exact setup and I couldn't get over just how much air this thing moves...I'm afraid to stand too close as I might get sucked in!
Old Jul 5, 2005 | 03:04 PM
007fl's Avatar
I have NO experience modding an LS1 so I may be simplifying this too much. How can a 90mm TB and 90mm intake make much improvement if all the air has to go thru an 85mm MAF first? Won't this create too much of a bottleneck to realize much improvement?
Thx
Old Jul 5, 2005 | 03:09 PM
LS1TECH Sponsor
The stock MAF and Lid are 75MM. the 85MM maf and lid are HUGE compared to stock stuff.
Yeah, all things being equal the MAF and Lid are still a little bit of a restriction. I don't think they will be much of an issue though.
Old Jul 5, 2005 | 03:12 PM
fearsom's Avatar
in theroy it will cause more vilocity, speed up the air so it shouldn't hurt IMO
ben
