Question on high idle after mods
Oh and I forgot to add, I pulled all of the air crap off also. I do have the SES light on right now, I just haven't had time to look at the codes, but I assume that is due to the air not being attached. I'm going to have the car tuned, hopefully this week or next week so if it is the air codes, they can do away with those codes, right? But this wouldn't have anything to do with this high idle issue would it?
THanks
PO121 Throttle Position Sensor Performance
PO410 Air System
PO412 Air Solenoid Relay Control Circuit.
I expected the PO410 and PO412, but what causes the PO121?
Or you have the throttle cable in the wrong hole. What year is your car and what hole are you using?
Check you PM's
Nick
Check you PM's
Nick
Bill Estes
Nick
How do you reset the TPS position?
Do you have a scan tool?
also you would hear to vacuum leak. Also check throttle cable binding.
Bill
