How hard is water pump replaement in LS-1?
Old Jul 17, 2005 | 02:05 PM
2000 TAWS6's Avatar
Default How hard is water pump replaement in LS-1?
Getting a puddle under car when it sits after a ride. Jacked it up and appears to be coming off the bottom of water pump area. Also wet on bottom of themostat area but doubt that is problem.
How hard is a water pump replacement on an 00" WS6?
Old Jul 17, 2005 | 02:44 PM
98Grnz28's Avatar
Water pump is pretty easy on a scale 1-10 it is 5. I would check the throttle body coolant lines for leaks.
Old Jul 17, 2005 | 04:51 PM
Krab's Avatar
It's very easy to do. Just unbolt your induction (from the throttle body to the lid), take off the accessory belt (15mm socket), and unbolt the six 13mm bolts that hold the water pump to the block. Then put everything back on in the reverse order and you're done.
Old Jul 17, 2005 | 05:49 PM
2000 TAWS6's Avatar
Couple of questions: (sorry if they are stupid)
1. Drain radiator?
2. Electric fans have to be removed?
Thanks.
Old Jul 17, 2005 | 06:01 PM
1QuickT-A's Avatar
You dont even have to drain the radiator or remove the fans. Just take off the lid, bellow, maf, throttle body, remove the belt and all the coolant lines and then remove the idler pulley from the water pump and then unbolt the pump itself. It is definately EASY! I just did mine about a month ago in about an hour..
Old Jul 17, 2005 | 07:07 PM
Lasershop's Avatar
Make sure the seal surface (on the block) is perfect before installing the new one. You will not have problems if so. Good opertunity to change belts if needed also.
Old Jul 17, 2005 | 08:40 PM
Krab's Avatar
Oh yeah, I had forgotten about the hoses that run to the pump. And the bolts are 10mm, not 13mm.
Old Jul 17, 2005 | 08:46 PM
01350ss's Avatar
should take no more than 25 minutes
my opinion - water pump replacement is easier than an oil change on these cars.
