Header install problem
Old Jul 17, 2005 | 07:33 PM
97TAWS6's Avatar
Default Header install problem
I am installing pacesetter long tubes on my 1997 trans am Ws6. The problem I am having is the steering linkage is not reconnecting. To disconnect it I simply pulled the one bolt out and pulled it apart but, it will not go back together. Any tips or tricks would be greatly appreciated.
Old Jul 17, 2005 | 07:53 PM
USMARINE1108's Avatar
I had to tap it in with a screwdriver from the top. that little bugger has to be lined up perfectly.
Old Jul 17, 2005 | 08:24 PM
SSBRONCS's Avatar
we took my brothers off from the bottom and slid it back in. it really is easier than it sounds
Old Jul 17, 2005 | 08:27 PM
Full-Force's Avatar
just take the bolt out of the bottom also and then put the top on first and then slide it up as high as it can go and then slide it down over the bottom
