ASP pulley question
Old Jul 18, 2005 | 10:38 PM
bodydropped's Avatar
Default ASP pulley question
Before my pulley I dynoed 346HP 360TQ,and now it dynos 376HP 383TQ.I guess my question is has anybody seen a gain like this.The only other mods i have is a SLP lid and a set of jet hot lt's.
Old Jul 18, 2005 | 11:19 PM
SS SLP2's Avatar
dyno foul up, difference dyno, difference conditions, pulley increase not likey to show on dyno ( the increse will be about the same as 10 hp increse)I may be wrong,I do not think any possible way a pulley is going to show 30 hp gain on dyno
JUST MY .02' Johnny
Old Jul 18, 2005 | 11:55 PM
SporkLover's Avatar
how long in between dynos?
Old Jul 19, 2005 | 12:13 AM
98BirdLS1's Avatar
IF those numbers are correct I'd say you are close to a dyno record 376/383 with just a pulley, lid, and exhuast is amazing.
What year is your car? And Manual or Auto. Alot of people don't get those high numbers with a cam, let alone minor bolt-ons, if that number is the truth, congrats.
But I would say it was a dyno goof. 346/360 are still VERY good numbers for you mods.
Luke
Old Jul 19, 2005 | 08:00 PM
My last dyno was a month before this last dyno with the pulley.It was also the same place(dynospeed),and it was only 3 degree differance in tempature.With just a lid it did 310 hp and 323 tq going thru a flowmaster.I took the cut out off and it went to 320 hp and 330 tq. then i did a clutch (centerforce dual friction),and I also did a SPEC 13 pd. flywheel.After that I did gears.About a month and a half ago i did jet hot long tube headers with dual 3 inch exhuast with x-pipe,and bullets.It dynoed 346 hp and 360 tq after the headers,and my air/fuel was PERFECT.The only think i changed was the crank pulley and the alternator pulley,and took it to the dyno a week later.It did 376 hp and 383 tq.This time with the pulley it was also half a point lean on the air/fuel.so running a little lean might have helped,but those are the only mods i have.My car is a factory freak i guess.I still have the stock intake(1998).I'm glad it's doing this kind of numbers,but i'm also confused.
Old Jul 19, 2005 | 08:03 PM
also ported mas air,k&n filter,and no egr stuff
Old Jul 20, 2005 | 08:07 PM
naw he sucks
Old Jul 20, 2005 | 10:03 PM
ULTIMATEORANGESS's Avatar
you sure its not a blower pulley?
do you have any ETs?
Old Jul 20, 2005 | 10:04 PM
Tally TransAm's Avatar
your car isnt a factory freak, the dyno is incorrect, not calibrated, or the correct factors are all wacked out
Old Jul 21, 2005 | 01:13 PM
RGR Pete's Avatar
If those numbers are right, I must go to the track and get my 11 sec. slip cause I added that pulley. I was going to add SLP Headers cause they add 40+ Hp but I decided against it become I only wanted 25 Hp. J/K
Old Jul 21, 2005 | 01:17 PM
Dustin's Avatar
damn, you should be a spokesperson for ASP, lol, they would get great business from your numbers.
Old Jul 22, 2005 | 06:53 PM
the dyno(DYNOSPEED) isn't that old and it backed it up three times
Old Jul 22, 2005 | 07:34 PM
Grimes's Avatar
you might have pulled low that first day for some reason? did you have any knock retard the first time round?
Old Jul 23, 2005 | 03:55 PM
02NBMFormula's Avatar
what brand dyno??? dynojet?
Old Jul 23, 2005 | 04:14 PM
4mula's Avatar
NOBODY has ever gained that much from pulleys, nor will they.
the dyno was off.
Old Jul 24, 2005 | 03:41 AM
it is a dynojet and i believe that some off the mercury readings are off.
Old Jul 24, 2005 | 03:53 AM
Redneck Z's Avatar
About as possible as a camel going through the eye of a needle.
Old Jul 24, 2005 | 04:27 PM
DarknessC5's Avatar
The Dyno correction factors were off... Ask the people that dynoed earlier from the WTFBA dyno day...
Old Jul 25, 2005 | 12:55 AM
how do you do that calculation to really see what i'm making
Old Jul 25, 2005 | 03:48 AM
DarknessC5's Avatar
Eric made a post about it on the WTFBA...
