Broken engine mount
Old Jul 20, 2005 | 11:34 AM
Sniper33's Avatar
Default Broken engine mount
What are the symptoms of a broken engine mount??
-Joe
Old Jul 20, 2005 | 02:55 PM
shouldaboughttheZ's Avatar
engine has vibration, especially at idle.
I replaced both of mine.
Old Jul 20, 2005 | 03:23 PM
777's Avatar
777
broken mount just means the engine would shake a lot at idle and if you revved it up it would go to one side quite a bit.
Old Jul 20, 2005 | 04:41 PM
Sniper33's Avatar
No vibration through the steering wheel and throughout the car at speed?? Just trying to rule out what my problem may be.
Old Jul 20, 2005 | 06:44 PM
00 Trans Ram's Avatar
When you rev the car, the engine falls out.
"I see someone here has jokes!!"
Old Jul 20, 2005 | 07:58 PM
Mainly at idle it will vibrate, mine did not do it through the steering wheel. I have an M6, and noticed it through the shifter alot.
Old Jul 20, 2005 | 08:15 PM
777's Avatar
777
You shouldn't notice it through the steering wheel, but should notice it through the shifter.
Old Jul 1, 2008 | 03:25 AM
Crimsonnaire's Avatar
Would a bad mount allow the engine to shake side to side at idle?
Where do you locate the mounts for an inspection, and how would they look if they're bad?
Old Jul 1, 2008 | 07:18 AM
TORCHD 02 TA's Avatar
You will feel vibration in the floor board under your feet, your motor will rock abck and fourth a lot..
Call Mike at WS6store. I just put in my ploy mounts and i got them next day as i live in IL and WS6store is in IA..
-Jonas
