pacesetter y pipe
Old Jul 20, 2005 | 10:55 PM
Fade2blk500's Avatar
Default pacesetter y pipe
Installed a set of pacesetter headers on a local guys car. Completed in 5 hours by myself with hand tools from pulling it in the garage to cranking with open headers. Now I am fitting up the 4 piece pacesetter y pipe. This thing doesn't fit at all! The passenger side looks to be about 6" short. Whats the deal, am I doing something wrong or does the pacesetter y pipe just fit this crappy. If anybody has some pictures of how it goes on, or any suggestions, they will be much appreciated!
Thanks,
Craig
Old Jul 21, 2005 | 04:43 AM
anyone?
Old Jul 21, 2005 | 08:03 AM
shawn's SS's Avatar
It should fit fine. MIne did. Are you sure you got the pieces together correctly? A pic might help.
Old Jul 21, 2005 | 10:32 AM
Bluehawk27's Avatar
Check the pic on TSP's website. then lay it out like that. I've installed a few of these and they fit fine everytime. Only difference is i used band clamps instead of those U clamps.
Old Jul 21, 2005 | 02:09 PM
Did it exactly like the picture, still comes short on the passenger side. I've installed a pacesetter y pipe a couple times before and it worked out. He is going to give them a call and see if we can't work something out. If not, a local exhaust shop should be able to add a piece of pipe to fix it.
Old Jul 21, 2005 | 09:36 PM
Full-Force's Avatar
Post pics of the pieces you have if possible. I have that y pipe and it couldnt fit any better. There is a trick to putting on y pipes because they have to be put together in a certain order to get them to fit.
