Can't figure out misfire
So last night, I swapped the plug wires in it, and now its doing it again. We were sure it was the wire, since it would come and go. Wouldn't think a coil or plug would do that, figured it would be more consistant. Am I wrong? Gotta fix it today... Thanks.
Kelly
http://obdii.com/articles/Engine_Misfire_UC.html
I'd replace all 8 individual gaskets (which is not that expensive) and within 2 hours, you'd be set.
Good luck.
Last night I decided to look around a little more on the motor and see if I could track down any kind of leaks. My car had been making a very audible hissing sound for a while now, and so I knew it was sucking air somewhere. I was looking with the engine running, and happened to put my hand down at the base of the intake to throttle body area on the pass side, and I felt air. I touched a hose there and it sucked my finger to it, and the engine idle dropped a little. Turns out the little 2" piece of hose that connects from the PCV to the intake had a hole in the bottom side of it. I replaced it with a small piece of heater hose and it was done.
Since, my car has ran perfect. I started it this morning to go to work, and let it idle for a minute before taking off. The SES light was on, but there was no stalling or misfiring that I could hear. This afternoon when I left work, I started the car, SES light still on but no misfire. I let it idle for a few minutes while I was making a call. Then when I got ready to take off, I noticed the SES light had gone off, and all the way home there was not one hint of anyting being wrong. Now, how could this vacuum leak cause my #6 to misfire, or was it even the cause of it? Is there maybe something else wrong as well?
I'd give the car a week and see if you have any more SES lights.
coilpack (coilpack/ swapped with a different cylinder to see if the code would fallow) nothing worked. It ened up being bank2 oxygen sensor had freyed melted wires so it was grounding out every now and then. You might as well replace that also. You also might want to clear your SES codes now that you think you got it fixed. this way if it pops up again you will know.
