O2 Sensors without Cats? Need help
I currently have SLP LTs with a catted y-pipe. However, tomorrow my race pipes are supposed to come in. I did not get the O2 sensors for them. I am not worried about the code (yet), I just want to know if it is okay to plug the rear O2 sensors back in. The holes will still be present in the y-pipe so I still need to fill that hole with something so why not the O2 sensor.
Also, lets say that I was to go and get tuned by HP tuners and they turn the no cat codes off. Would it still be okay to have those rear O2 sensors in there to fill the holes? Then, say I had to put the Cats back in just for visual inspection, would it be okay to still have the O2 sensors in there?
Basically, wtf do I do with that hole and do they still some sort of thing that you can cover those with like block-off plates?
Thanks for your help
Thanks for your help! I was able to find the 02 sensor plugs. What do I do about the end where something is plugged in though? Do I just put electrical tape over that connector?
