Need Bellows without MAF??
Old Jul 27, 2005 | 02:43 PM
Bill Bowling's Avatar
Post Need Bellows without MAF??
I am planing on removing my MAF and wanted to know what everyone is using as a bellow between the TB and Lid.
I guess I could go to HomeDepot but would like to have something that looks good.
Bill
Old Jul 27, 2005 | 11:23 PM
slowpoke96z28's Avatar
try a short piece of 3 inch exhaust pipe in th section where th MAF was. what engine management system are you going with? Speed density? Alpha-N? or something else?
Old Jul 28, 2005 | 03:23 PM
SD.
Bill
Old Jul 30, 2005 | 06:56 PM
Unhappy
So no one makes something to go beteen TB and aftermarket air lid??
Bill
Old Jul 30, 2005 | 07:33 PM
TAQuickness's Avatar
Hey Bill - I'm in the same boat. I just got done with the micrometer on my 85mm MAF. As it turns out, I have one SLP slashed exhaust tip in my parts bin, which ironically has a near identicle ID as the 85mm MAF. I was planning to cut it down and use it inplace of the MAF.
I think I have enough material to fab 2 of these. If this works out ok, and you don't mind splitting the cost of the tip with me, I can send you the other one.
If it doesn't work, I was planning on browsing the plumbing section @ Home Depot.
Old Jul 31, 2005 | 03:09 PM
Talking
I already made an insert for mine last night. I used a 3" S&D Coupling PVC part#22733 from Lowe's. It cost $1.08.... I put the SS on it. I had one left over from my calipters. I had to cut the ridge out of the middle and I also painted the outside black. It does not look to bad. See picture. I would still like to have a bellow that went from the lid to the TB. If you find someone that has one please let me know.
Bill
