Anti-seize on header bolts?
Old Aug 6, 2005 | 05:22 AM
Schantin's Avatar
Originally Posted by Xtnct00WS6
I'm doing an install of Pacesetter headers. Should I put either anti-seize or lock tight on the header bolts? Should I just put them in as is?
Thanks!
Use anti-seize. You'll probably have to retorque the header bolts a total of 3 times before the toru stabilizes on them..... but it's a lot better than snapping one off in the head later down the road (when rying to remove them for whatever reason) because you used nothing....or worse, slapped lock-tite on them!!
Speaking of lock-tite. Some might argue that it's a good idea. For example, the LT1 has lock-tote from the factory on the header bolts. Which is why so many people have had probs snapping them off when trying to remove for an aftermarket header install!!! The LS1 does NOT use locktite on the threads.
Old Sep 10, 2013 | 05:02 AM
trevmust's Avatar
loc-tite is a brand name.
Old Sep 10, 2013 | 06:49 AM
lastcall190's Avatar
The comment 8 years in the making...
Old Sep 10, 2013 | 08:55 AM
demonspeed's Avatar
It's not mine! woo hoo!
Looks like a good time to bust this out:
But to contribute as 8 years is a long time... I used Alper (eBay brand) stainless header studs rather than using the pacesetter bolts. I put a small dab of red threadlocker (the Permatex brand) on the nut. They've yet to loosen; however, I've only put maybe 500 or so miles on since the install.
Old Sep 14, 2013 | 12:17 AM
01ssreda4's Avatar
Originally Posted by OneMeanZ
When I put LTs on my old LT1 I just put the header bolts in....
That's because you take no pride in your work. Sorry to respond to this ancient thread but anti-seize would be the correct answer.
Old Sep 14, 2013 | 01:13 AM
ls1 1990 VN's Avatar
Little bit of Copper grease on all threads, also use it on all wheel studs.
Old Sep 14, 2013 | 09:38 PM
orthopod's Avatar
Due to my experiences this past week with a stripped out M8 1.25 by the PO and his drill and tap to a M10 1.5 in the worst possible location (rearmost header bolt on passenger side bank) that is now stripped I will suggest that you just stud the thing. I may have fixed it with a step stud and thread locker but in the future I will only install heads or headers with studs.
Old Sep 15, 2013 | 12:04 AM
01ssreda4's Avatar
^^That's completely unnecessary.
 Michael S. Palmer
Old Sep 15, 2013 | 12:52 AM
orthopod's Avatar
Yes it's unnecessary now but would be a nice thing to have in case he starts taking the car apart and putting back together like legos as some of us like to do. I wouldn't do it on a pacesetter install with stock heads but when I upgrade heads I won't think twice about doing studs as it just takes one time to have an issue and all of a sudden studs look cheap money and time wise.
