How do I get my oil fill neck out of the valve cover?
I don't want to break anything, but the SOB is not budging. Jesus I've done H/C by my self and I can't get this piece of plastic out of a hole. Let me know if there is a simple way to twist, lift, pull or something.
Thanks in advance.
Tom
Thanks in advance.
Tom
Originally Posted by 98hc4mula
NO, its not that simple. you have to take the valve cover off so you can press a lock piece of plastic that prevents it from twisting, this is done with a 90 degree pointed needle like screwdriver.....
David
David
Originally Posted by WhiteRhino
I've only taken off 3 and never had to remove the cover.If you give it steady pressure it will twist off without breaking the plastic,even though its still hard to get off.
