Duals under the axle guys...
In order to get the mufflers to fit, they said they would need to modify the floorboards. I really would like to avoid this:
1) Are there any mufflers as quiet as the Borla's that flow well and will fit under our cars without modification.
2) Those with under the axle, would you recommend this system and any suggestions that you can offer?
3) Any thing else before I take the plunge?
I made them myself and then had an exhaust shop weld it together. I havn't bottomed out and no floor board modifications were needed. The only place it bumps a little is right after the drivers side header, I'm in the process of fixing that. I used Sweet thunder mufflers, its a little loud but sounds great.
1) I don't know how the Borlas are but I can tell you 2.5" dynomax bullets are LOUD!!!!!! I have chambered mufflers (the old round 1969 Camaro style) now and they are a much better sound...
2) I went over the axle when I redid my car because:
a) I always wanted them over the axle
b) I didn't like having to drop the rear half to work on the rearend
BUT......overall yes, if I had another car or were telling someone how to do it, I would say go under the axle because:
a) going over the axle takes A LOT OF WORK (unless you ditch the upper panhard rod and thats a bad idea I think)
b) dumps before the axle sound bad/look bad/and all around I just don't like
One thing I would do is have a flange on your pipes before they go under the rearend. I didn't and the first time I needed to work on something major, I had to drop the entire exhaust out (though if you build the system right, the rearend should just slightly touch the under axle pipes when hanging on the shocks.....at least mine did......).
3) don't do 3" if you are lowered ANY unless you like dragging over everything....there just isn't enough room under these cars to run 3" pipe effectively and still have ground clearance.....2.5" is plenty.....and do an X-pipe....
But it doesn't seem like anyone can do it without welding something to my chasis or modifying the underside.
I think I may just buy the Bassani and have it modified to the headers...
Will over the axle solve that problem? I am seriously considering the Bassani True Duals. Expensive, but I don't want to sacrifice ANYTHING, including car modification and the ability to perform routine maintance on my car.
SLP Over-Axle Exhaust Pipe #10166
Let me put it this way, if you want to sound like a dump truck, by all means go with the powersticks. If you want wild rasp and loud as **** go with the sweet thunders. Now, if you want a nice deep, refined sound WITH ZERO INTERIOR DRONE then go with the xr-1's. I also have a sound clip of my exhaust(racing of course
) just pm me ur email address, and ill send it away and or if u use AIM. Let me put it this way, if you want to sound like a dump truck, by all means go with the powersticks. If you want wild rasp and loud as **** go with the sweet thunders. Now, if you want a nice deep, refined sound WITH ZERO INTERIOR DRONE then go with the xr-1's. I also have a sound clip of my exhaust(racing of course
) just pm me ur email address, and ill send it away and or if u use AIM.or just do this
Here is some pictures of the TD's that our local shop Pro Dyno does under the axle. It doesnt get much better than that guys!
