Can o2's cause this much of a problem?!
Old Aug 4, 2005 | 04:55 PM
Mssingkid's Avatar
Default Can o2's cause this much of a problem?!
Trying to get to MA from Ny i ran into some problems... I started to lose lock-up on my TC on the highway, but that was only the begining. Soon after the car started to run like crap. No power, felt like i was in a constant deadspot as if i had no stall. So naturaly i thought" well thats it trannys fried". After being on the road for almost 6 hours i get home to find a check engine light on. I go to autozone to pull the codes and find out, p0131 and p0151(o2 sensors bank 1 on both sides?).I haven't purchased them yet but looks like just about 70 bucks each. Is it possible that both sensors failed at the same time..?
I didn't think the o2's could cause so much havoc on my car. Do you think the o2 is screwing with the pcm, and thats causing the random loss of lockup?
BTW- Are these the o2's before the cat... and how hard is it to replace them..?
Old Aug 4, 2005 | 08:28 PM
JBIRD02's Avatar
Yes, o2's can really cause the car run bad. I got some water in my o2 extension during a heavy downpour, and my car ran like total hell, like it was running on 4 cylinders. The only reason I knew it was the o2 sensor was because I noticed my a/f gauge acting up, and sure enough, thats what it was, just a little water. I wouldve never thought that a o2 sensor could cause so much trouble.
Old Aug 5, 2005 | 07:40 AM
TAQuickness's Avatar
When the PCM throws the O2 sensor codes, it imediatly falls into open loop. The factory OL tune is a "safe" rich tune to keep you from going too lean. So, yes, bad O2's can really muck things up.
Replace the front O2's with Bosche 13111's (Vette rear o2's). They have a higher wattage heater and should work well with your future LT's.
Old Aug 5, 2005 | 07:16 PM
Mssingkid's Avatar
Can i purchase the vette's at an autozone?? If so what should i ask for??
I'm going to get the Bosch one's tomorrow after work then jack the front and hope it'll be an easy swap. Anything i should look out for?
Old Aug 5, 2005 | 08:58 PM
Go to autozone and ask for 2 bosche 13111's. While you are there, pick up a Haynes manual for you car.
Old Aug 5, 2005 | 11:40 PM
Cstick's Avatar
The vette 02's helped my problem. Check your plugs as well. I did both 02s then decided to look at the plugs before I finished and it was the driver side sensor that was bad. All 4 plugs looked terrible compared to the passenger side. That side was running way rich.
