First header install (pending) in 20 years, LOL
I have no idea what type of gaskets are supplied, but intend to get new GM (I have a high mileage engine) and that's what most seem to go with. Sound good?
I'm 54 years old, and I believe this will be the last time I crawl on the ground to do a mod, LOL.
Any suggestion welcome!
. While you're down there, replace the front O2's with Bosche 13111's.
Also, the header install is much easier if you lift the motor with a jack stand about an 1" or 2"
6 MUFFLER BEARINGS!!! well I'll be...
)Not sure if I'd use black RTV on the clams either. It will bake in with the heat. Nice quality band clamps should be more than sufficient on their own. It will allow for easy disassembly for later work that involves removing the exhaust as well.
Replacing the O2's is a good call.
Not sharpshooting....just my $0.02
Oh yeah, don't forget to use a dab of anti-seize on each header bolt. Some might disagree, but it will save you lots of grief down the road if you have to take the headers off (like a head swap or engine rebuild).
I also definitely agree with using anit-seize. If you are worried about the header bolts coming out, use locking header bolts.
I didn't need to raise the engine with my flowtechs either, the headers just slipped right in. I had to remove the steering shaft, but after its removal the header went right in.
It seems every new year I install headers or cam I find myself more tired and sore afterwards than the previous year--I guess thats what its like getting old huh--I don'tlike that to much. I hope I still have the motivation to install headers at 54!
last project was a '69 camaro
when i got my LS1 took me two weeks to find my distributer
seriously, and then... lca, fipk... well you get the idea, did'nt know the lingo.
learning tho read about a 100 times more than i post.
and the getting up and down (god i hate putting it on jackstands) keeps us off the couch.
good luck... and hat's off to a fellow car nut!
OLD GUY'S RULE
