stock exhaust manifold question
Old Aug 10, 2005 | 08:03 PM
JustAnIlluzion's Avatar
Default stock exhaust manifold question
are all the ls1, ls2, ls6 exhaust manifolds exactly the same?
Old Aug 11, 2005 | 11:13 AM
LoudmouthLT1's Avatar
I believe the 00+ are supposed to flow better then the 98-99. I don't know if they have a larger diameter or what.
Old Aug 11, 2005 | 11:50 AM
98z28chevy's Avatar
Samething i hear 00+ flow better.
Old Aug 16, 2005 | 08:58 PM
JasonWW's Avatar
The 98 and 99 are double walled tubular and pretty restrictive. The 00-02 are cast iron and flow better. I can't comment on cars other than the F-bodies, LS2 for example.
Old Aug 16, 2005 | 09:52 PM
JonB's Avatar
The LS6 are different and do flow better than the 00+ f-bodies. Awhile back CHP did a comparision of ls1 manifolds(not sure of the year) ls6 and a set of 1 5/8 and 1 3/4 headers and the ls6's only flowed a little lower than the 1 5/8. I can't remember the numbers but it was's much.
Old Aug 16, 2005 | 10:24 PM
RedHardSupra's Avatar
ok, so could i put a 01 header on a 99 (i already have air/egr gone anyway)
Old Aug 16, 2005 | 10:31 PM
TAQuickness's Avatar
01 fbod header on a 99 fbod will fit. Should look a bit better with out the egr fittings too
Old Aug 17, 2005 | 07:03 AM
JasonWW's Avatar
It's funny, I have a pair of later model cast manifolds in my garage that I was going to swap my 99 manifolds with. I was going to do it because the car was under warranty, but now that the warranty is over, I'm going to go straight to long tube headers.
