PCV valve question?
Old Aug 14, 2005 | 01:08 PM
1ORANGEWS6's Avatar
Default PCV valve question?
Can it cause a your car to surge froma vaccum leak? I replaced the valve right before the H/C install with an Autosone valve. Do I need to buy one from GM or will the one from Autozone work?
Old Aug 14, 2005 | 03:37 PM
obZidian's Avatar
not sure on the autozone piece but if im not mistaken; a pcv valve is a um....well, a valve. If it doesnt work, meaning it is not opening it wont cause a leak.
MAybe you already know this but this is the first thing that comes to mind...
good luck!!!
Old Aug 14, 2005 | 04:49 PM
1ORANGEWS6's Avatar
I wondering if its stuck open not closed.
Old Aug 14, 2005 | 08:57 PM
Cstick's Avatar
I doubt that is the problem. Plug it off, and see if it helps any, but I bet it acts the same.
