ls6 intake..why 2 part #'s?
Old Aug 14, 2005 | 11:56 PM
ls2 bait's Avatar
Default ls6 intake..why 2 part #'s?
the stock manifold off an 01 f-body #88890523
the one of an 01zo6 88890524
what gives? i thought they were the same?
Old Aug 15, 2005 | 12:06 AM
spy2520's Avatar
I think the throttle cable bracket thing is different. If you use the z06 one you will have to do some custom ****, where as the f-body one should be just like yours for the most part.
Old Aug 15, 2005 | 12:22 AM
98z28chevy's Avatar
I have a question i ordered this LS6 intake manifold #88894339 is that the same as the other 2? this one is a manifold kit i purchased from Gmpartsdirect.com for like 388.00 comes with all new gaskets etc... Can i just bold up my Throttle bracket to the LS6 intake?
Old Aug 15, 2005 | 07:02 PM
MM98's Avatar
Yes, I ordered the same one.
Old Sep 25, 2005 | 11:34 AM
FRCBobby's Avatar
Which one would I need for a 00 Vette?
Old Sep 25, 2005 | 11:40 AM
mattslightning's Avatar
i got one that came off of a 01 Z06 for my camaro what i found out the throtle cable bracket Z06's do not have the have electronic throtle body so where the bracket bolts the intake did not have the bushings i used a couple of washers bigger than the bushings and the bolt to remove bushings the just used a socket and hammer and tapped the bushings into the Z06 intake
