ls6 intake question
Old Aug 27, 2005 | 03:26 PM
slimcracka's Avatar
Default ls6 intake question
ok if i was to get an ls6 intake what all do i need to install it and forget about it? i know about the coolant tubes but what else?? thanx and for another question what all bolt on wise to i need to run like an 8.2-8.3 in the 1\8 with an a4? ill have bfg drag radials but what else.. and its a 3.23 car too..
Old Aug 27, 2005 | 04:17 PM
conan's Avatar
You will need block off plates for the egr, unless you have "race" headers.Also get yourself a converter to match your gears.
Old Aug 27, 2005 | 04:37 PM
Dustin's Avatar
you need 1 coolant line, 2 coolant plugs, and one egr block off plate if you dont have racestyle headers as said above.
Old Aug 27, 2005 | 08:01 PM
kissell_13's Avatar
race style headers? sorry i'm a newbie
Old Aug 27, 2005 | 08:04 PM
conan's Avatar
The race headers have no previsions for the air system or the egr, you can buy headers that have ports for those system.
Old Aug 27, 2005 | 08:45 PM
Full-Force's Avatar
what does the car run now? what is your 60'?
You will want to take your car and stall it to 1000-1200 to get the best et from it assuming it hooks which it should with stock gears and auto with drag radials.
I think you will run mid to high 8's like it is. The first thing I would do is exhaust. If you cant afford full exhaust right now then I would get Longtubes, ORY, and a cutout in your stock I pipe. If you cant afford that then get a cutout, lid, and do some free mods.
That should get you in the low 8's. The best my car has gone is 8.05@89 with the mods in my sig but its a lowered car with a 6 speed and it will not hook even on M/T et street radials. 8.0 was with a 1.98 60'.
You should be able to get 1.8's with drag radials.
Old Aug 29, 2005 | 12:01 AM
98z28chevy's Avatar
Hey dont forget to get new gaskets for the cross over pipe and the plugs theres little metal clips with a seal that help the plugs and cross over pipe from leaking. i paid like 25 bucks for 4.
