Ticking under accel????
Old Sep 6, 2005 | 11:49 AM
skywalkrNCSU's Avatar
SSU, come over and relax
Default Ticking under accel????
when i drive my car now (not very often because of gas prices) i notice a ticking sound whenever i hit the gas. do you think that this could be an exhaust leak or maybe it just needs to be tuned?
Old Sep 6, 2005 | 11:52 AM
ArcticZ28's Avatar
Could be an exhaust leak or it could be your AIR check valve. Try to get down in there and see. Or, if you have some time and are willing, remove the AIR system and see if it goes away. My bet is that it's AIR.
Old Sep 6, 2005 | 11:58 AM
i dont have AIR since it is a 98
oh and egr is gone
Old Sep 6, 2005 | 12:14 PM
ArcticZ28's Avatar
Then that leaves exhaust leak. If it was tuning, the only ticking-type sound would be pinging. Or maybe you just developed some good old piston slap... but I doubt it's that.
Old Sep 6, 2005 | 05:49 PM
RPM WS6's Avatar
LS1Tech Administrator
Community Influencer
oh and egr is gone
'98s have AIR, every year of LS1 F-body has an AIR system. The only way that you wouldn't have it is if you already removed it.
Have you checked the oil? Maybe it's low, causing some extra valvetrain noise. Could also be an exhaust leak somewhere. Ticking can be so many things, anything from exhaust leak to valvetrain issues to noisey injectors to normal exhaust noise that you just aren't used to since you don't drive the car much now.
