stock I pipe and bullet muffler?
Old Sep 10, 2005 | 04:15 PM
TruBloodTransAm's Avatar
Default stock I pipe and bullet muffler?
hey guys my current exhaust setup consists of Pacesetter LT headers, Pacesetter ORY, and a stock catback+3" cutout right after the rear axel
anyways the car is way to quiet when the cutout is capped and it's way to raspy when it's open...I really don't want to waste money on an expensive catback b/c I won't gain any hp over the open cutout...
so I've decided to add a bullet muffler to my stock I pipe to try and reduce/eliminate the rasp...my question is what diameter is the stock I pipe? (so I know what size bullet muffler to get)...also what length should the bullet muffler be? 16 inch? 18 inch? is there a certain brand that's better than another or are they all pretty much the same?
thanks!
Old Sep 10, 2005 | 04:46 PM
FatZ28's Avatar
I had the 16in one in my ipipe. Got it out of sumitt..
Old Sep 10, 2005 | 04:47 PM
rich Z's Avatar
It's 2.75 inches meaning 3" muffler. This is a powerstick on my otherwise stock exhaust. http://s95410392.onlinehome.us/JBrd4.../RichZ_rev.mpg
Do I search here for a Powerstick if you like it.
Old Sep 10, 2005 | 04:55 PM
if the diameter of the stock I pipe is 2 3/4" shouldn't the inlet/outlet of the bullet muffler be the same diameter?
I don't understand how you can put a 3" inlet/outlet bullet muffler on a 2 3/4" I pipe
Old Sep 11, 2005 | 01:29 AM
FatZ28's Avatar
Any respectable exhaust shop can make it work...
Old Sep 11, 2005 | 06:35 AM
mushroom281's Avatar
i did the same thing and welded with a 16 inch bullet and welded a the cutout at the end of the I pipe but left the stock exhaust the rest of the way back so it looks stock and sounds almost stock with the cut out closed , with their windows up next to me at the redlight they can't even hear my cam
Old Sep 11, 2005 | 03:14 PM
mushroom281, so how does it sound?
did you notice a significant reduction in the rasp?
I assume you used the stock I pipe as well...so what size (inlet/outlet) bullet muffler did you use?
Old Sep 11, 2005 | 03:15 PM
I took it to a local performance shop and they put my car up on the lift and the mechanic said he couldn't do it, he was saying something about how there was very minimal clearence between my I pipe and the floorboard....and then he went on to say that the 1/4" gap between the 2 3/4" I pipe and the 3" inlet/outlet bullet would be to much to try and fit
Old Sep 11, 2005 | 04:18 PM
Uno99's Avatar
Then he sucks and I would not let him do any work on your car. Shop around you will find someone.
Old Sep 11, 2005 | 04:26 PM
99SSLS1's Avatar
What you do is cut the spot out for the bullet. Then take the piece you cut out, cut it in 2 and expand it to match the bullet. Now you can either weld the 2 3/4 pipe end back to the I or have them expand it alittle more and it will slip over it also.
Old Sep 12, 2005 | 12:15 AM
so how much do you think I'm looking at for the price of a 16" bullet and labor?
I just want to get an idea of how much I'm going to be spending
thanks!
Old Sep 12, 2005 | 01:34 AM
DOUBT IT's Avatar
ele-blue95 and I put the Sweet Thunders on my duals today ( and GOD do they sound FRICKIN SWEET ), and he put one of my old 18" bullets on his car. Granted his car is an LT1, and it took some careful cutting and welding, but it fit just fine and it killed ALL the rasp, with the cut-out open or closed.
Just my $0.02
Old Sep 13, 2005 | 08:03 PM
well i have full lengts and a 3 inch offroad y pipe and theit is ZERO rasp it has a real muscle car sound and with my big cam it sounds reeaal good
