ASP Pulley question...Tried to search, but no luck
Here's my story. My trans am had a lingenfelter top end kit motor that was pulled out of a corvette dropped in after my original blew. What's the difference between the corvette pulley and the f-body pulley? Also, I need to get the overdrive pulley for the alternator because of my stereo setup, but didn't see it listed in the corvette section of online stores only the f-body. So, the question is: Which crank pulley do I need to get, and can I still use the overdrive for the alternator? Also, would the belts I need be different from the usual f-bod setup with the underdrive crank and overdrive alt.?
use the fbody pulley
why would you need the corvette one? just because you have a 'top end kit motor' or whatever doesnt make any difference. the alternator/ac/powersteering are going to be in the same place..
just buy the fbody one.
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
Firehawk#608 do you have any aftermarket amps? I'm pulling with two MTX amps and my voltage tends to drop now when I turn it up especially at night when the headlights are on. I wasn't sure how much of a difference it makes. Thanks
![Sad](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_sad.gif)
Do you think I could get away with a beefier alternator instead? I don't want to take away from the crank pulley gains too much. I've got one amp pushing 6x9's and components and another pushing a small sub. But most the time, I am listening to the exhaust ![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
I just want to make sure, I need the f-bod pulley even though the motor was taken out of a corvette? Thanks for putting up with my ignorance...
